Man if we meet I owe you a drink.
I just made tons of screenshots for those who struggle with the setup. Step by Step through the Wizardsā¦
http://www.vesc-project.com/node/20
Frank
Nice with some dokumentationā¦ thumbs up
Any news about the R = 0 bugā¦ so i can follow your FOC tutorial ?
I just updated my vesc from 4.12 to 3.29 and everything went with zero problemos.
I just have this one issue of setting up my controler. I use a PPM(Benchwheel) controler with thumb throtle and i already set it up with wizard but for some reason the throtle distance that is available is very small. I know it prob has to do something with throtle curves that i know nothing about. Does anyone have any idea how to set the curves correctly, so that i can actually use the hole wheel of the throtle (i mean half of the wheel, backwards is ofcourse brake, which i think also needs adjusting). EXPANDING THE THROTLE.
If you used the app wizard I camt imagine why it wouldnāt have all the range.
Because 3.29 changed back to current control to fix the braking. A later version will likely have watt control back with fixed brakes.
@rok @Jinra Has nothing to do with that. The VESC-Tool has never used āwatt controlā in the fist place. You should have the entire throttle way anyway. The power distribution along the throttle way has something to do with your settings. Try setting Motor max Amp = Battery max Amps (if you battery is strong enough) for a linear power distribution along the entire throttle way. You will only get realistic results when you run the board under load. You canāt see the result on the bench, since it is a current controlled system.
Frank
@Pimousse Yes ! Even if not grouped correctly I could just arrange the sources. But I kinda filed to extract them for now so thatās a stalemate.
@BigBoyToys Actually it is a different fork older than VESC 6 (creator started working on it since 4.8hw versions). Could still benefit from making a VESC 6 variant based on mines and it would work very good though. Thatās next step once Iāve ironed mines out and stressed them as much as I need (6xx can only do better IMO with same mods).
My units are LM5109 based (replace the DRVs, good up to 100V) and also have 6-FETs all on one face kinda like VESC 6 and FOCBOX so as easy to cool down. But I donāt have Direct-FETs.
I also GPIOs assigned differently (probably due to modular layout, LM drivers + boot and reset buttont to switch between normal USB and DFU-USB connections).
@trampa Thatās not what @Ackmaniac said and he gains no money from saying it did till 3.28 version.
Just did what you said and i noticed no difference. Time to take it for a spin outside, so that i have a better answer for you. Thanks though, very nice and user friendly tool!
TESTED The throtle feels very different under load, i like it. I also like FOC. And turtles
I do have one question tho regarding brakes. This may not be the vesc or software problem but rather my settings. When i pull the throtle way back it does break, but does so very slowly, and never totaly stops the motor from spinning. It doesnāt blocks it completly is what i mean. How to fix it?
I am running 10s4p with 200kv motor. I have a motor max set to 60A, brake max to -60A and regen to -16A.
i donāt know if someone asked it beforeā¦
1- itās safe to use this new software with a vesc 4.12 ?
2- if you want to use it in a vesc 4.12 you have to upload another firmware?
thanks
yes on both
Hi @rok, -16A is not a lot of current for the brakes, so donāt expect to much. -60 for the motor regen doesnāt help to much if your battery can only swallow 16A. This weakness is dominant at speed and will get better when you slow down. At top speed your brakes will be limited to -16A, since the motor generates nearly at full system voltage. The lower the voltage drops on the generator side, the more Amps the motor is allowed generate. On the battery side the VESC will scale up the voltage again, lowering the currents back to your 16A battery min value. This means: If your motor generates 32A at 20V (=640W), your battery could be charged with e.g. 40V, 16A (=640W).
In consequence the battery min pretty much defines your brake power at high speed, while the motor min value becomes more dominant at low speed. The further you spread the values apart, the more you will experience a non linear behaviour of the brakes.
I will try to make a Duty Cycle manual together with Benjamin to explain the matter in detail. So do some test runs in an area where you face no obstacles to find your settings. Battery min is the bottle neck for strong brakes at speed! This is why you want a strong battery pack allowing fast storage of energy. This is why you want a high P count.
The motor brakes will not stop your board totally! It gets better with sensors, but if your board doesnāt move, your motor wonāt spin and canāt generate electricity. If it doesnāt generate electricity it doesnāt create resistance. VESC-Tool has a feature called āhand brakeā, actively braking your motor through the use of a current flow through the motor coils, blocking the motor from spinning up. This consumes energy from the battery! You canāt easily activate it from the remote at this stage.
Frank
Did i miss the point why Ben canĀ“t just programm the Vesc 6 braking behavior like the 4.12? So you get the same experience with same settings like before?! Brakes where beautiful and worked like a charm on 4.12.
My settings look like that on a dual 6355 drive with a 10s4p: Motor -60A Bat -12A Brakes are nice and strong at all speeds and block the motor completly when standstill.
So shouldnĀ“t be a problem to get the same results on VESC 6!
Hello guys, I uploaded an incorrect FW version, then in order to correct it I ticked on Show non-default firmwares and now I canāt even connect.
Iām having an error Invalid seial port: \.\COM6
Did I brick my VESC?
Update: I cycled power and now I can connect again, but I canāt change the HW version, as soon as I click on connect the Hardware Version List deletes 4.12 and only shows the HW 48
How did you fix this issue, Iām having the same issue as you, I incorrectly uploaded the HW Version 48 instead on 4.12. I canāt upload the 4.12 hardware version anymore, is there a trick?
Download FW for HW 4.12 from vedder github. Use the custom file tab in VESC Tool to upload the firmware
Actually switched back to extended BLDC tool using this method
I downloaded VESC_default for hw_410_411_412 from Vedder Github, flashed the firmware and Iām still stuck on hardware 48. Any other ideas?
There are other firmware inside the hw_410_411_412 folder
VESC_0005ohm.bin VESC_servoout.bin VESC_ws2811.bin
Should I try those as well?
If you upload BLDC firmware and back to vesc-tool firmware it might give you option for 412
I tried to use BLDC tool (old software) but I canāt even connect, Iām getting this error:
The firmware on the connected VESC is too old. Please update it using a programmer
Iām getting worried, I could use some help
