Next week I should be getting all the parts to build my first VESC I have one major concern and that is I am not sure what components do the polarity matter on. Does anyone have a list or images that show what components to make sure are the right way or direction. Is there any other tricky things I should prepare for. I made my own solder oven and I ordered my boards and stencil from dirtyPCB.
He is asking about the orientation of the components. Do they have to be in a certain orientation so they don’t short? How do you know which way to solder them.
alright i figured the LEDs, Schotty Diode, and im sure there are other was just hoping someone had a picture with them high lighted i noticed some of the parts on the image i posted previously some parts have a black line on the edge of them not sure why though.
Diodes-
Component: line marks the cathode
Silkscreen: could diode symbol or just a plain line to mark de cathode
Led-
Component: check the component datasheet, usually green dot on the bottom marks the cathode
Silkscreen: same as diode
Tental capacitor-
Component: line on component marks the positive side
Silkscreen: thick line marks positive
Intergrated circuits-
Component: little dot in the corner of the component marks the pin 1
Silkscreen: a dot should mark pin 1
Connectors
Component: this one is tricky, depends on the manufacturer, usually pin 1 is marked
Silkscreen: usually the component pin 1 pad is square, or can have a dot
For the other components, fets, shunts and voltage regulator… Well you should figure that one for yourself
I forgot to mention which side for the LEDs on the VESC. Its not silkscreen on the pcb. I had to check the comments on Vedder’s blog of the VESC to find the direction of the LEDs.
Alright so i finished the board today but havent got to test it out yet i have a couple concerns…
when i put the board in my soldering oven some of the components move so i had to straighten them out with my regular soldering gun and i home i didnt over heat them or anything. Another issue is there is bridges all over the place in the small processor and motor driver. See images. also on the fets it looks like they might be shorted across the pins does anyone know if this will cause issues and can i try flash the firmware on it or will that mess it up?
Already clean it all up looks good and yeah first time ever using a stencil and there was a couple other issues i had with my homemade oven. Going to try flash it tomorrow morning crossing my fingures it works… Does anyone know if a 50v 1000uf capacitor on the battery wires will work instead of the 60v 2200uf?
