Hi
I have been trying to have the on-chip debugger in Eclipse 4.6 (Neon) working with no success.
I have tried to follow these two web pages, although out dated: http://vedder.se/2012/07/get-started-wi … ntu-linux/ http://vedder.se/2012/12/debugging-the- … d-eclipse/ (zylincdt eclipse plugin is no longer available)
Hence, I am using the last openocd release (0.10) and the last gcc-arm-none-eabi toolchain (5.4) through the ARM GNU Eclipse plugin: http://gnuarmeclipse.github.io/
I have tried:
- a lot of gdb commands combinations (also searching on internet) through the eclipse “Debug Configuration” window and tabs
- a lot of ticks/unticks on the eclipse “Debug Configuration” window and tabs
- gdb version 4.9 and 5.4 toolchains
Outcomes:
1
- [ECLIPSE ONLY] When I use eclipse only, the response when I launch “Debug” is not always the same (sometime gdb fails to connect), I’d say random (inconsistency of the stlink_v2 usb dongle? It’s this one: http://www.ebay.com/itm/222120784635?_t … EBIDX%3AIT) 1.1
- Those times that eclipse manages to connect and start writing the image, there is a strange timeout that make gbd terminate with exit value: -1
2 - [NO ECLIPSE] When I do not use eclipse, I can SUCCESSFULLY connect the debugger and start debugging when I launch openocd server and gdb client from the terminals!
3 - [HYBRID] When I launch openocd server from the terminal and leave eclipse run the gdb client, those times that eclipse manages to connect and start writing the image, there is a strange timeout that make gbd terminate with exit value: -1 3.1 - I tried to use “set remotetimeout 5” (default is 2 sec) and “set remotetimeout unlimited” with no effect.
My question is: what’s the problem with eclipse?
This is the output of gdb in the best case: // stm32f4x.cpu: target state: halted target halted due to debug-request, current mode: Handler HardFault xPSR: 0x01000003 pc: 0xfffffffe msp: 0xffffffd8 Info : dropped ‘gdb’ connection Info : accepting ‘gdb’ connection on tcp/3333 Error: address + size wrapped(0xfffffffe, 0x00000004) stm32f4x.cpu: target state: halted target halted due to debug-request, current mode: Handler HardFault xPSR: 0x01000003 pc: 0xfffffffe msp: 0xffffffd8 cleared protection for sectors 0 through 11 on flash bank 0 auto erase enabled Info : Padding image section 0 with 48704 bytes //
This is the script that I am using in the “Debug Configuration” window, “Startup” tab, “Initialization Commands” pane (the rest I kept default, although I tried a lot of combinations as I said above) // target remote localhost:3333 monitor reset monitor halt monitor flash protect 0 0 11 off monitor flash write_image erase “/absolute/path/to/eclipse/project/build/BLDC_4_ChibiOS.elf” monitor reset monitor halt //
