hey @Ackmaniac, what does orange color on the block header indicate?
That you reached the battery cutoff start. When you reach the cutoff end it will turn red. By this you see that you touched a limit. The temperature box also does the same. It means that the power getās reduced to stay in the limits so that the battery doesnāt get over stressed and that the VESC itself doesnāt overheatā¦
Yea now that you say it, itās obvious.
Is there a way to backup setup info /modes /trip info to migrate to a new phone?
Same problem here, any update on this?
I also have noticed this. Im using the galaxy S8 plus and 3.26 fw.
Quick question Anyone have the app properly running on android 7.0 My phone wants to update but Iām not going to allow it if i risk the app Thanks
No worries, itās compatible.
Thanks. I will update then
Just released a new update which should gives a better VESC-Tool Firmware support. For the VESC-Tool Users i recommend to use Version 3.28 because there a UART bug has been fixed.
I also added a better battery support so that different battery types can be choosen. (Li-Ion, Li-Po and ANR26650 (A123) and Costum). Li-Ion are adjusted for Samsung 30Q Batterys. Just spent a lit of time to get a good preset for each type. But still each one of them can be adjusted individually.
Also fixed a bug for the warning notifications when the battery runs low.
I have been having an issue with the app. Both when I had android 6 and now with 7. Occaisionally (I havenāt been able to find a common reason) the app freezes. It will show the frozen values on all boxes and no information in the notification bar. And if I close it and open it again it will show an empty screen work no Bluetooth devices to connect to. I have to open app administration and force close the app. Any clue why this could be happening?
It crashed a lot for me as well (Android 6 and 7). Just updated to Android 8, Iāll give a try this evening and report.
Also the app crashes when I try to delete a board, just after I type āDeleteā
Just released a new Version where the Range and the Delete Bug is fixed. Thx for the info.
Just released a new version of the app which asks you to disable the battery optimization for phones with Android M or higher. That hopefully fixes some issues that people have with more modern smartphones.
Any idea why I canāt scroll through the settings in the mode setup?
Sorry misreading the labels!
Brake setting is Motor Min
No sorry. No idea and first time I hear that. Do you have a modded firmware?
Edited my postā¦ Sorry
I was looking for ābrake maxā and should have been looking for āMotor minā Doh!
