It looks like the DRV8302 of my VESC has suffered a massive failure. It was purchased from Enertion earlier this year and wasn’t ridden particularly hard. I started braking, the board came to a halt and never restarted. My friend told me that some smoke had come out and here’s what I found:
I saw a few comments about bad capacitors triggering that issue. My questions are:
Is there a most likely cause to this issue?
How can I ensure it doesn’t happen again with a new VESC?
HW config details:
Motor: 3.2kW 63mm motor:
KV: 170
MAX POWER: 3200W
WIRE WINDS: 10
MAX AMP: 80A
MAX VOLT: 10S
RESISTANCE: .56
NO LOAD CURRENT: 1,4
Battery pack:
2x 5s in series
8000 mAh
30C discharge
5C max charge rate
Wooow, that’s one for on the wall ! Also curious on how to extra-protect the DRV chip since I also blewn one already (BLDC)
What is your enclosure made of? Because carbon enclosure can shred, leaving bit of highly conductive carbon shorting the board.
EDIT: also you need to give your drv some love… or it can cry tear of fire…
My guess is a small metal debris getting between the pads of the controller chip.
Blasto
August 16, 2016, 1:22pm
5
That almost looks like a massive overvoltage failure, does your soft switch allow to regen the battery?
Hey @JohnnyMeduse , the enclosure is made of ABS.
@Blasto , yes the soft switch does allow to regen the battery, it’s been working fine that way for the last few months.
Blasto
August 16, 2016, 4:47pm
8
I just looked at the high rez, man that is some massive roastage, not sure the pcb is salvageable. C39 just blew up, no where to be found.
sl33py
August 16, 2016, 5:01pm
9
WOW. That’s pretty epic. Sucks, but impressive failure. This obviously isn’t the usual DRV failure, so i’m not sure anyone here can tell you how to avoid. Did you do anything differently? Were you braking down a steep hill with the battery already full charged? That voltage has to go somewhere… but i’m just guessing.
It might be worth posting on vedder.se forum and seeing what they say - but be as specific as you can on details. Might also send back to Vedder to do VESC autopsy!
GL!
My vesc also went but on the first trial run, in bldc, still waiting to hear from warranty
chaka
August 16, 2016, 5:58pm
11
I sure Benjamin would love that! Just the other day he was telling me how much free time he has.
sl33py
August 16, 2016, 6:47pm
12
LOL - yeah, i know. However i know he’s done this in the past. Not quickly, but still may be worth looking at. When he can get to it…
@EvanAndDadProd wow that’s probably the worst one I’ve ever seen!
I’ve posted the question on vedder.se as suggested. We’ll see what comes out. The thread is here .
this deserves some kind of award. Its as if Lord Skatan reached in and shot fire into the heart of this poor bastard himself.
Did those heat sinks come with the Enertion VESC? I thought Chaka was the only one that had those.
They were ordered off eBay separately.
kyo
August 18, 2016, 6:51am
18
@EvanAndDadProd
Hi, can i ask how did you stick the haet sink on the vesc?
kyo
August 18, 2016, 9:17am
20
Thanks man, appriciate it
