@laurnts Thanks for posting this. It’s reassuring that when I finally do jump on the VESC train, I’m gonna be able to program it without destroying it.
Next update will have online firmware updates with a tick box for vesc hardware version and maybe auto hardware detection so no confusion, I’m also going to make a quick start wizard.
Awesome.
I don’t have the VESC yet, because of the current delays, but I just downloaded the BLDC Tool to take a look at. Also can’t donate now, but will in the near future when my summer hours pickup.
I think we should have some topics like this pinned to the top of the forum. This will get buried and newbs will come ask questions answered right here.
Or better yet, one that links everything together that is pined to the top. People are a) lazy and b) don’t always know what term to search for. I think that would help
Hey new member here wanted to ask, I have a 12s battery supply and a 12s 170kv motor. What parameters do I need to set? In bldc mode, like besides the motor config where is has all the volatge and stuff what do i change? Also is it okay to us the 12s supply to program the vsec? I’ve herd i need a external supply.
depending on were you got ur vesc from, the reason why some recommend to use a power supply is becasue most of them are not tested and there might be some shor in the vesc from factory i got mine from ollin board wich is by far the best vesc out there and they test each one of the vescs leaving there warehouse when i got mine i plugged mine straig to my fully charged 12s and everything worked just fine
How do you power up your vesc when programming? I did read somewhere on this forum that a special power suppley is only nesceseray when the vesc-x is booted for the first time?
And how is this with the newer vesc-x?
some people selling vesc test them prior to shipping, so they´ll do that for you. After that you can just throw your normal batterys on there. If you buy somewhere else or want to go 100% safe, power it up with a low voltage battery, like one 3s or like @chaka mentioned somewhere, use two 9V batteries in series.
Great, thanks for clairfying that. Makes the vesc a lot more usable for me.
When I click on the link it says that the Service is Unavailable. Is there something i’m missing???
the site is down. I recommend you get Ackmaniacs BLDC tool instead:
Okay, if I go to test with 2 9volts in series, how do I know if something is actually wrong? Assuming there is a fault in using 18 volts so the fault is indicated by heat and not by fire or sparks correct?
where did you get your vesc from? Nowadays they should all be able to be powered up with your normal “ride”-battery. If you stil wanna be 100% sure, power it up with 18V, connect to a pc and get it connected to a vesc-tool. There will be no sparks or something If a vesc is damaged it´s really rare that you have a minimum of smoke because of a damaged resistor, but that´s all.
I got mine from flipsky, they have no reviews and don’t say that they come tested so I really don’t know what to expect
should be ok with your normal battery, but like i said, if you´re unsure, start with the other battery to power it up the first time
Okay, if something is damaged the vesc tool will show a fault code?
if you go to terminal and type in “faults” yes
So, my VESC didn’t come with a micro usb cable and i dont think ive seen one in 5 years… Is it a bad idea to replace it with a mini usb from an old android phone? Or should i find the right cable?
I think you’ve got those flipped, it uses a mini and Android’s have used micro.
Besides that, no definitely do not replace it. You’re risking damaging the vesc before you ever even get to use it.
It also uses a mini because it’s a very robust connection to the PCB. It’s just in general stronger, which is important for an expensive device that could be effectively bricked for the end user if they don’t have a way of fixing it.
Just get the right cable. they’re more common than you might think, plenty of Arduino based boards use it, and just DIY electronics in general. Some even use usb B type connectors.
Okay so I’ve got 18 volt, the negative of the battery going to the negative of the vesc and the vesc plugged into the computer but there are no option coming up under “port” and the auto connect feature won’t work either…
