Hi I believe my VESC is shorted but I’m not sure.
I do not get any faults code.
When I power the VESC, it does not blink red on startup.
But when I move the trigger it lights up the white led but does not move the motor.
When I spin the motor with my hand, it shows in the graph the rpm of the motor.
So what is wrong with this VESC? Did I blow it up?
I think something similar happened to me when I was setting mine up. I’m still a noob at vesc anything. Is there any chance that the control mode is disabled from when setting up PPM?. Just a thought. Best of luck.
Edit* maybe share your screen shots so others may help.
Well I figured out mine blow up. It was not very easy to see, it works fine but not the driver chip. The routing with the capacitors were blown away so there are no more. And with the blinking was it resetted the config to the default.
