you posted this yesterday. when’s the group buy happening cmon fellas @mmaner @thisguyhere lol. I really want one of these and i feel like it wouldn’t be too difficult to design a pcb you can buy with all the parts so you can put it together yourself. An electronics store in here in australia does heaps of these solder-it-yourself kits. I think that’d be cool?
And you would be incorrect
I do live in England though.
could you please double check the new name… It´s not DAVE… you think VeGa will work non the less or people will refuse to buy it as they think it is vegan food?
You’ve lived there far too long then.
I’ve discussed this with my extensive marketing team and they agree that Dave is still the best name for this device
Schematic?
@akhlut Here’s the schematic and a draft of the PCB layout (the “PCB v0.1”). Any comments are welcome. My background is not in electronics. I’m a pure hobbyist so there’s likely a lot of room for improvement in the design.
Same. I just like to play.
Where can I find/buy/know what gaskets that will be good for this little project?
I’m not sure yet, I haven’t started yet, need measurements and it’s likely to be a couple of weeks before the display and parts get to me.
Once I have aRough XYZ values I can get an idea of what prr-made gaskets will for without much modification and then design the enclosure around that.
It may be easier to make a change in the enclosure for a silicon bead instead. Still too early to tell.
Is the display available on Amazon? I don’t mind paying a bit extra just so I don’t have to order though a Chinese site and wait for shipping.
I saw that one but I think it still comes from China so there is a long wait.
Thats still weeks for shipping even though its on amazon…
Ooops yah beat me to it!
Oh didnt know that
I should have bought one from Taobao when I had the chance
Found it with prime
HiLetgo 2.2" ILI9225 SPI Serial Port 176x220 TFT LCD Module with SD Socket Support 51/ARM/Arduino https://www.amazon.com/dp/B00LSG5HI0/ref=cm_sw_r_cp_apa_EQtYBbHMD4P7P
Edit I just noticed that link is the 2.2" display don’t buy that one it’s too big.
Nope, already tried that, they flagged my post so I deleted it. Different screen/module!!
Yeah just noticed damn
I was looking for some dimensions to get started on a case concept. I found this. I assume this is accurate on the hole dimension and that the doughter PCB will have the same hole spacing? Apparently wrong, this is the 2.2" size.
I went ahead and made a quick concept as small as I could make it. It uses a 3mm piece of Acrylic to cover the screen that should be epoxied to the case. Four M3 Socket heads hold it all together and compress an o-ring on the bottom for “water proof” ness. There is still a question about water proof buttons, for the communication cables I would just expoxy / hotglue where they come out the case. The bottom part I did not model yet. The schematic from @janpom showed two buttons that’s why there is two round holes on the side.
Also I am sad to say its going to be too big to fit inside the truck bolt pattern.
Bottom side where o-ring goes, then compress by bottom half part not shown.
PCB assembly.
Cross section.
All of the vertical dimensions for the PCB’s are just a guess at this point.
Anyone know of some really small waterproof buttons?
*Thought. Maybe the case does not need to be two parts with o-ring. Once you confirm it works, fully pot the inside with epoxy and use the 4 bolts to attach it to the deck. Well that is one way to get it done! Actually you need to disassemble to re-program it if there is an update to the firmware, so fully potting it would not be good idea.
