Hello guys i am planning to use some hoverboard wheels to build a skate i need 71v to have decent speed on them but the vescs usually don’t go above 60v , i was planning to use a ebike controller but they only support wired throttle anyone heard a way to connect a wirelless receiver to a ebike esc maybe some convertion board that let me connect the receiver to the ebike throttle input…
there are hoverboard wheels that can handle 71v…? jesus christ
id be asking maybe on endless sphere
This sounds super scary. I’d be very careful the brakes don’t toss you off at high speed
Take a gun and shoot yourself, it will be faster and less painful. Seriously dude don’t do it. It’s a suicidal build.
I don’t think 72V will be dangerous, there are enough E-vehicles which work on 16S-20S but you need to check the sensor wires because maybe they have a different wire position. Ebike controllers normaly have regenerative breaks so that should be nice.
Can’t you just plug in a receiver? I know the throttle wire have 3 wires red white and black. Maybe it just works with a normal receiver
In what world would you need 72v?? Vesc has regenerative brake by default…
These hubmotors have a very low Kv so you need higher voltage to get decent speed.
Let’s assume that the motors won’t overheat or break at the required speeds you are looking for and stop for and second and think…
If you can afford the high end hardware and battery required to drive a system at this spec why not just build with the much cheaper already available parts? Most of us here use 10-12s with a list of success and speed and torque.
I want to be positive about this but you are honestly setting yourself up for failure and I don’t want to recommend you doing this with the high likelihood of injury ot causing a fire…
These motors have very low rpm to have a decent speed you need to overvolt them… its not the same like doing it on a regular skt hub motor :-), some ppl report getting to 40 km/h on 72v…, may it works connecting the reciever directly but i think its a long shot i dont know if its the same /compatible signals…, the esc have to have regen ovcourse, its only a project , if you guys have any positive information about these i apreciate it…
Do you have found a better way to put those hubmotors on the trucks? Maybe they fit on the meepo style back trucks?
I think if you found a more reliable esc that works with higher voltages this would be a fun project.
The ebike controller is maybe a bit to difficult to work with a wireless remote.
Yes i have those kind of trucks and will try to fit 2 motors on them… , first i will try with a vesc but i dont know how high voltage can i use withouth burning them… , maybe 52v …
12S won’t be a problem for the motors. I should try with max 12S (50.4V) for a vesc. And keep the current low, 10A per motor.
