Yep just plug into bms, you might need to lower max voltage using the pot(assuming it has one) on the PCB in the charger, if the BMS will have lower cutoff voltage
Ah okay gotcha. Makes sense! Thank you for the useful information. Iām guessing I would want to set it to the max charge of my lipos, so either 4.210 or 4.110 - 42V exactly or 41V?
I am interested in buying 2. Pls let me know when itās time to pay. I am in the US. Ca
Yeah thatās it. I think charging any lithium to 4.2 is harmful and a bit silly, Iāve never encountered a mass production device, like every laptop on the planet, charge above 4.15 per cell. There is simply no benefit at 4.1-4.2, you only lose cycles and with lipos early puffing.
this module doesnāt go up to 12s
i think these may fit the bill:
12S 44.4V Protection Circuit Board for Li-ion and Li-Polymer Battery Packs
iāve asked pricing for each, waiting on response.
was just advised these are available only up to 10sā¦bull
Well could still get those for 10S Iāll have a look at 12S options
http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/PCM-D108.html
http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/PCB-D245.html
Some of us want more range and less sag on our rocket powered murder boards
Iām looking at 10S
ok, for 10s then we can get PCM-D190, no problem.
PCM-D108 is discontinued:
thatās fine, i just found end of charge voltage to be lacking so stepped up to 12s. a 12s4p is has eight more cells than 10s4p but itās just stronger all through the charge range.
You can ride a 12S5P and Iāll take a 10S6P
when did you order this?
beginning of september.
What about this one http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/PCB-D245.html
The reason I didnāt go with that one is that itās a bit high at 1.5cm and the balance leads face upward meaning you need even more headroom to have it fit.
ignored anything above 15a charging, whoās got a 20a charger? the more capable the module, iām thinking the pricier itāll be (assuming of course).
and what @Jinra said.
Huh? You mean HCX-D190? Or do you have a link
http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/BMS-D140.html L75mmW65mmT8mm
dammit max, i already feel bad about the million questions iām asking.
iāll sneak this one in after i get a response.
Lol itās their job
