I used this wheel. But This wheel will also need to be machined to fit the bearing.
https://www.monsterscooterparts.com/front-razor-ground-force-go-kart-wheel.html
What machining did you need to do?
This similar listing for two wheels says it comes supplied with 608z (regular skate) bearings…?
What pulley did you use with this setup?
Hi Lee, What pulley did you use?
That setup looks really nice.
@Rosco Hi Ross, i expect they needed to be machined as the spacer is 20mm inside instead of 10mm as per the usual skate wheels.
@junhyun is my assumption correct?
Cheers, Patrick
thinking of trying to use some offroad rc tires on a hub motor eboard. want it to have offroad capabilities. anybody know some that would fit well on a 60mm hub or on a some extra 90mm wheels i have? thinking i could figure out a way to glue on the tire to the spare wheels?
Yes i am curious also. You used a ‘Metal Drilling Machine’ correct? I want to do the same thing. I have been trying to figure out which trucks I could use that would fit these wheels. Glad to see someone figured out how to do this. It is inspiring. Regular skateboard wheels on my Evolve are too slippery on the streets. Not enough control and stickiness at high speeds.
