@Wajdi with .42 photon firmware on new style receiver with whip antenna and using Acks 3.38 firmware I am unable to perform a ppm pulselength map. I can see the green graph raise up and down as the joystick is moved but not in the input setup wizzard app. I am receiving data on the remote such as V, A, P, ect.
Also, with the A.Off setting on the remote turned on , after the set time is reached it turns off as designed. Then when trying to turn back on it will flash the screen and not turn back on until the battery plug connection is reset.
Is this remote still not compatible with @Ackmaniacās firmware v3.101?
Iād love to get this remote for the turn signal functionality, but only if I can still use ESC Monitor with BT on the slave to change settings on the go like I do with acks firmware.
@Deckoz mentioned using ackmaniacs firmware with this remoteā¦ Any update from you by chance?
@skatardude10 I have seen several using Ack firmware successfully with Photon remote however I did not test it personally. Maybe someone who is using Ack Fw can confirm.
Does anyone else have a problem with the remote taking a long time to pair with the board when turning on, if I take the enclosure off and short the bind pins it works but that is a dick around.
If I leave the remote sitting on the board for a while Iāll come back and it will be connected, shouldnāt it connect straight away?
I just came back from a ride where it stoppped working half way through, before my ride I had to remove the enclosure and bind again.
Ive just removed the enclosure to investigate and have found that the antenna square thingy has fallen off the receiver.
How is it secured to the pcb, it almost looks it was only held on by the hot glue gun glue.
That explains the pairing issues, seems like a bad solder joints. I will receive a new version of the receiver by the end of this month, and I will send you a new replacement.
@Wajdi gāday mate hope you count my remote and receiver on these batch as I cannot wait no more to use these highly demanding awesome remote
See my last email just to remind you
Hey guys,
Just a quick update, a newer version of the Photon is currently in production.
Improved receiver design, now with micro USB to update software.
New NRF modules with FCC certification.
Binding using a micro button instead of jumper.
Hardware improvement of the remote, now with hard reset function.
Receiver
Remote
For everyone that has a preorder pending, you will get the latest version shipped in about 8-10 business days.
