Yes sorry about that, the port was later changed in software
I don’t think it will bind without an update because the packets have been changed, the new receiver and new software now supports up to 4 receivers, with one master and 3 slaves, I also fixed the total distance counter, and tweaked other things.
It should be really just a couple hours before I release it.
Hi Guys - Having a bit of trouble getting photon to connect to vesc - any clues
Photon remote binds OK with receiver - remote light flashes green showing connection
steady green light in receiver
VESC is focbox with 3.34 FW
Have set App to UART with 115200 baud rate
Photon remote does not show any vesc data and shows 255.2 in FW rectangle at top of remote
Has anyone figured out how to eliminate the cut outs. My remote won’t stay connected longer than 5 seconds at a time. I’ve wasted 5 hours on this thing
@Mattmccrary8 Seems like an odd issue, can you check if there is any fault on the VESC?
@mmaner He already has the new receiver, which has an outstanding range, I suspect there is something else causing him problems.
