[UK/EU] Nickel strip 8mm x 0.15mm (everything else sold)
Hi,
To be honest the 3 boards I have will not be best suited for the 95kg range. If you look at the above chart, a 16 or 17 ply long deck will be the best option for you. :+1:t2: I did have a 16 long but it has sold now. I have a 15 long but like I said I believe you may be better with a 16ply or 17ply.
ainda disponível? envia brasil não?
could you please write in english? I´ve seen a few other posts from you - so please use english only!
não é possível,tarzanbk…acho que só eu uso tradutor… it is not possible, tarzanbk … just use translator alone …
I think it would be better if you used the translator to translate to English, since the everyone here speaks English even tho its not their main langue
@isqueromeroderviz Penso que seria melhor se você usasse o tradutor para traduzir para Inglês, já que todos aqui falam inglês, mesmo que não seja sua língua principal
@Acido this is a google auto translation of your wise words in portuguese :joy:
¬¬ eu tinha compreendido,estava/estou traduzindo agora…relax. finally send to Brazil now that I translate for English? certainly only reino unido?
Is the nickel pure nickel not plated
Hello,
Can you send me a private message. I could send to Brazil. I’ll look into postage.
:+1:t2:
Yes pure nickel. I have done the usual tests on it and it welds fine. :+1:t2:
Interested in the Trampa MTB 15ply, How easy would it be to convert to an Eboard?
Only one short trampa board left :+1:t2:
Sold
Only pure nickel strip left :+1:t2:
How much for the strip
I do still have it. You can have the lot for £20 if you like
