I’ve been having a hard time trying to figure out what battery charger to get, and after reading all the battery charging posts on this site, I haven’t seen this unit even mentioned. Has anyone had any experience with this charger?
It seems to be quite a bit more powerful than the popular 50W B6AC and 80W Accucel chargers, but is still reasonably affordable. Currently ~$65 on HK (U.S.-West), but can be had for $57 using the buddy code links on rcsearch.info:
In my estimation, charging a 6s 5000mah battery at a 2c rate would take around 30min. on this charger vs. 1.5 - 2.5+ hours on the B6AC & Accucel chargers.
If anyone is interested, the 250W 10A Reaktor is on sale for <$25 ($23 if you wait for the pop up deal) on Hobby King (US). That’s less than the BA6C or Accucel. The 300W unit was backordered, so I found this 50% off deal instead.
Hey! I’m also in a search for a suitable charger… So what was your final choice then?
I’m using CalcRc to calculate the approx time it would take to charge the batteries… and yeah would be willing to charge at 10A, 5A for each 5000mah 3s pack, Because charging 6s (2x 3s serial) packs with 2.5A each, would take something like 2hours… I would be happy to get that number to 1hour… so that i could get a chance to ‘‘quick charge’’ if im somewhere out of home with the board and have to recharge the batteries outside of home.
So far I have found the Accucel 6, which is capable of 7a charging… which is a lot more decent than imax b6 with 5a/50w.
Keep in mind that a “fast charge” is not that good for your lipos. You will stress them and they will not last as long as you would have charged them slowly.
Another keypoint of fast charging is that the chargers are more expensive!
Keep in mind the watts the charger can output. At 6S and 1C (so 5A) you already have 126W.
If you charge every battery separately then this will double your charging time again.
Your best bet is to get a 6S charger and charge them in series. At 1C it will take them an hour to be full. But as @DeathCookies has already said: the faster you charge the more it will damage your batteries. That is why I charge at only 0.5C and up to 4.1V instead of 4.2V
Also in series you don’t need 10A to charge them at 1C - you still need 5 and only the voltage goes up. In Parallel it would be the other way around
Do it correctly!
I just bought a 1080W power supply and a 400Watt dual output (800Watt) charger.
Then i can charge two 6S batteries with 18A each. So i can charge one of my boards (2x 6S 8Ah) in a half hour. That is fast charging but i nearly never do that. It is much wiser to know when you have to charge and if you are in the hurry you should swap it with a charged battery.
Good point actually… perhaps I should just invest in bigger or more batteries rather than fast charging… since the weight should be very similar between carrying extra batteries or carrying a charger + psu around…
Anyways… will probably go for accucel 6, as that is able to charge a little bit more faster than the imax b6… since 1c is 5a, and Im probably going to be charging with 3.5a (0.7c) one 5000 3s pack, which is still quite good
I just use an old Computer PSU - get the 12V cable and ground and you are good to go.
They are super cheap and almost everybody has some spare ones lying around.
With usually at least 250W they are also more than capable of supplying a large enough current.
You can even make your own adapter to hook the charger up to any PC PSU - so no reason to carry the PSU to work for example - just hook it up to your PC under the table.
FWIW, I use two of the Reaktor chargers mentioned by the OP. It is a re-branded Junsi 206b.
I ride 12S4P, but built my pack as two 6S sticks. It is certainly not terribly convenient that I have to pull the cover off to get to the balance leads and charge connectors. I could in theory rewire everything to bring charge and balance leads to the side of the enclosure, but I doubt I will bother. I charge the entire pack at once, each half on its own charger. I charge at the standard charge rate for LG HG2s, 1.5A/cell or 6A total for the pack (since they are wired 4P). I run a 3.1V cutoff and 4.1 charge, so it takes about 1.5 hours to charge the pack and maybe another 5 to 10 min to take apart the board and put it back together and what not…
Anyhow, since I’m not running a BMS, it gives me some piece of mind knowing the pack is fully balanced every charge. The cells are staying very well balanced at this point… which you’d expect of (what were) new HG2s.
I bought a Meanwell, but haven’t gotten around to doing a constant current mod to it yet… I may do that and bring out a charge connector so I can charge it without taking anything apart, and do periodic balance charges as needed…
Here is my “all in one” charging setup. It allows me to charge two 3s 5000mah Lipos in parallel at 8 amps, so full charge takes about 1:15 or so at 0.8c charge rate.
I’d really like to try one of these, but I haven’t been able to find any reviews on them. I may just buy two to try them out and to save on shipping, unless someone in the San Francisco area wants one too?
The only way to connect to the pc psu is to get wires which you connect to the disk drive or hard drive… or have you found another place where to connect more directly?
No problem if it a pc you use often and can make the wiring accesible from outside… not so useful, if it is not your pc… and have to ask someone to open up the case and get the cables
something like this
so you can cut of the sata part and solder whatever plug you need on there. With this you just go to any PSU and hook it up to a free molex plug.
Yep that’s what I imagined. My idea is to use (borrow) laptop chargers… they wont be as beefy but their voltage is usually higher. Also there’s no need to take the cover off of a pc and search for molex cable…
Though it would be required to have multiple female laptop ports available, to be able to get the juice from them…
Btw there’s also a similar charger but just with 10A rating. Ppl said it also has junsi firmware n such. It’s called “Antimatter”. There was quite a good deal for it on banggood. About 50usd.
