Read about problems with blowing fuses, so i´m going with a 25A cuircet breaker instead of the normal 16A one… no problems by thi first 10S-5P battery…
Going with 4 nickel strips 7x0.15 in parallel for about 80A continious
Each 1S5P area is connected with a 10AWG silicon wire for the needet flex, balancer wires addet and heatshrinked :
Haha to be honest this kind of mounting the enclosure will eliminate any kind of flex
You have to add slots on the bottom side too! Then you will gain more flex.
I wanted to test how it feels this way, and yeah if you want it more stiff then this is your way
You are right about the sunkko, could be something DocBrown have used
First 50km yesterday made yesterday, loving this FOC mode, so silent…
This was yesterday a run of 20km with a average of 19km/h,
i charged back 8375mAh, so about 17wH / km … not bad i think, only carving no straight runs…
I think you will get nice 30km range at least with this setup, the motors are to high KV i think …efficience will get even better with some lower KV ones which fits better to 20-30km cruising speed… the actually topspeed i dont need
In generall the 213kv is too much on 10S Battery for safe use… but hey this is what i got left and i dont pull the throttle full on fresh charged lipo… for FOC use u dont need any special, just done the motor detection…
I have the Urban carver board in the mail. Do you know if i could just change the 7inch Wheels to some Street Wheels like you ? Or am i doomed to 7inch.
Btw. what screws are you using to attach the battery enclosure to the board ?
nice built, but it definitely looks too stiff right now, it barely sags in when you carve and you carve it quite hard already, nice rear breaking loose at the end, thats how it love it too! it all becomes so much better if you store energy in the board at the end of each turn!!
Thanks Dude.
You can flip your trucks and mount street wheels, then it is a street carver (-;
I´m using M5x10 screws, 12 per side actually just treaded in the Deck without inserts.
Thanks Simi, yeah its really really stiff right now.
As i mentioned it was a test how it turns out with only one side slotted,
will add the other slots soon … interrested how much more flex i will gain !
Yeah this break out thing is fun as hell, love it
Scary
You should go at least in the outer spring position with some preload for speedruns IMO
Yes this kind.
I cut the tread direct in the deck, secured it with loctide.
Done similar conections for Rc-Plates and it worked good.
Maybe although a questions of how often you will tighten it ?!
Using Tread Inserts will be better of course, but the good is you can still do later if this dont hold up …
I was a little in rush before my holiday, soldering this battery and mounting was alot work by doing it the first time (-;
