Wheel side will actually affect how your curve is as well, when i switched to 107’s with 16/36 still as my gearing ratio, i had to give myself more initial oopmh in order to contend with that gearing ratio. So i made the beginning more linear.
the straight line from the 2.54 bldc tool is just awesome if you ask me. You can see your starting point (pink linear graph) and then edit the curve but still have the initial for reference.
Rule of thumb for acceleration: above the line is harsher, below is mellow. (As compared to stock)
@mmaner i actually like that curve better than mine i tried downgrading from 3.1 to 2.54 last weekend but you can’t jump backwards from ‘3’ to ‘2’ software is what i found
You should be able to use the 2.54 ESC Tool (ack) and downgrade the firmware to 2.54. I’ve done it on FocBoxs a couple of times. If you need some assistance hit me up.
looking good brudda. If you get bubbles, use a sewing needle to pierce the bubble then push the air out. A heat gun will work too on small bubbles. Just be careful as the heat will release the glue so they’ll slide if you touch them.
My nano x flashes green too when charging. I contacted enertion support and was told this was normal. It does not stop either when fully charged.
The former one I had that broke which obviously came from a different production batch goes red when charging and shows a solid green when fully charged.
