I’ve had the same thing, I usually just leave it plugged in. Typically its a balance issue and the reading is within the margin of error. Off that your charger goes to 50.7 though, that’s a little concerning. Whats the amps on it?
Hmmm, I would let it go another 30 mins and see what happens. Can you get to the balance leads and check the voltage on the individual groups?
Alright, I will give it another 30
it’s probably not necessary. is this the first full charge and were the cells at the same voltage when you built it?
Oh yeah. All same same.
And yeah, first full charge
OK, 1st charge is always a littel hinky as everything balances and the individual groups settle in. I would give it another 30 mins and see what happens but keep an eye on the pack voltage via multimeter. The lcd voltmeters are sometimes off by a volt or more.
And… like most of my concerns…
All good! I guess… it took it to 50.5/50.6, but turned green a after like literally 5 min.
@Deckoz looks like I am going to need your help toning this charger down a smidge
So I had the BT module hooked up to acks app last night briefly before bed.
Now, my board is greyed out…
what happens if you hit scan again (top right)?
Nothing earlier, just closed the app again, reconnected and it was red again… cool. But no telemetry coming through
Double check the that the baud rate is 9600 and its set for PPM and UART.
Ahhh, had to ride. I will deal with BT later!
Still have to put on the hexagon griptape; it is going to look sooo mean… I keep on trying to decide the best way to keep my gaps between the hexagons even… this task has been plauging my mind a bit. Don’t want to fuck it up.
Hexagons laid well look amazing… Hexagons placed poorly… well, honestly look like shit.
Get Y tile spacers. I’m doing that now for some spuds
uxcell Wall Floor Tile Plastic Y Type Spacers Tiling Tools 3mm White 200pcs https://www.amazon.com/dp/B01N940AUA/ref=cm_sw_r_cp_api_i_LsBiBb9X2RD1E
Excellent Idea!
Hey man… sorry…busy day. Work and picking up a gem
If you need help adjusting the charger, give me a buzz tomorrow evening
Nice!!!
Looks great!
well how was the ride
