Interesting wish list, and I suppose it’s great to aim high ! 100km on AT wheels is probably going to be optimistic (at best). Certainly will be if you like the look of stealthy boards and standard under deck battery enclosure mounting. Of course anything is doable but the results won’t be pleasing on the eye!
Looking forward to seeing how you progress on this project.
without optimism (and some craziness) you won’t be able to achieve something great.
But you’re totally right, my realism says it won’t work, but let’s see
Totally agree. It’s just I like stealthy boards, and whilst I get why mtb esk8 need top mount batteries, I just don’t like the look of metal boxes inbetween the foot placements. This is probably the only way you’ll get that many cells needed for that much range though.
Without to promote myself
I‘m running a quad with pneumatics and nothing sides separated from each other
If you want an insane range I wouldn’t recommend to go quad. It’s just not really efficient. The same with chains, they cut you range over belts.
I have 2x 12s 5Ah lipo packs and I get like 12-15km out of them.
What you could do is to split your battery in two parts.
A12s8p in a Eboosted enclosure under your deck and a 12s8p top mounted.
With it you can also connect the two sides independently from each other.
I don’t run a bms as I use a balance charger for my lipos, but I use a fuse for each battery pack to save it up.
I‘m not expert on dd, but how you want to mount them on a trampa deck!
The deck has a 35degree angle on the nose and tale.
Normal longboard trucks will not fit there.
like I said, I have no clue what deck I could use that fits everything, is stable and also suitable for offroad driving
I’m still thinking about an Evo tho
It would basically just act as a second loop key from the Battery to the ESC thats in an easier to reach position, maybe even ontop of the box? Using right angle XT 90s you could get a decent seal…
okey, I see it, but… I would prefer to not have more holes in my box as urgently needed and I also don’t really see the use case -> when my board goes crazy I don’t see me grabbing that loopkey…
No focboxes in there…
But yes i can just pull it out if I want.
It’s an xt90 anti spark plug.
It’s not likely that it’s pulled out on speed if I don’t do it with my own hands
And even than the power just drops and the board rolls out
