Just playing around to see how its best to modify my mount to fit the new profile, unfortunately these is no easy/cheap way to make the angle adjustable, but it appears that I can rear mount the motors and still have lots of ground clearance
I will need to wait for the actual trucks to arrive, I don’t trust this model I downloaded, and also appears that the profile of the TB trucks are bigger than normal calibers
How do you plan on getting the 10s10p to fit on the hummie deck? will either of the packs be flex packs? The Hummie deck does flex but very slightly. Do you have the files for the 3d printed enclosure as well?
Edit:
checked out your previous build where you’ll be moving some of your parts from. Are you using the same 3D printed enclosure? Does it also allow for some flex?
They will be double stacked, probably I will need to go 10S9P because as you said the deck has a slight curvature
Each P group will be rigid, but the series connection flexible
The enclosure will be all new, I need to have the deck in hands to model it first and also test for flex, if it’s just a little bit the ABS can handle just fine and it will be easier to print since I can make it flat and use the screws to curve it, Hummie said that the arc will be about 3mm down at the middle of the compartment in comparison to the edges
With a wide axle a la TB218 I’d go for a sleeve motor mount design just like what Trampa is using or what kuglis is doing in his gear drive. It’s bullet proof and easy to maintain.
Thanks for the idea, if I have to make a new mount I will probably look into doing that way
For now my old mount will be used, it’s just a matter of enlarging the circular that was used to mount on the Paris, way cheaper because this mounts were expensive to machine (but still cheaper than ordering a decent one from overseas)
Looking a lot better with the cover. Usually I make the cover with complex curves, but since the Gummies are almost a disc, a simple cover ended looking better
Also modeled the 6.5" tires, I may need to shift everything a bit to clear the belt from it
Now it’s obvious that I will need to drop mount the trucks, may need to sand a lot of the tail of the deck
First, on all my board I routed the motor wires thought the middle of the deck, but it’s a lot of work. Also for this board I want sensors on the motors, and to this day I haven’t found a connector good for this
My plan was to 3D print a channel, extend the motor and sensor wires and plug directly on the VESC, but since the Hummie deck has a drop it would be a pain do print it right
This pictures than Frank posted made me realize that it will be a lot easier and look way better just to use mesh on the wires and send them to the back of the enclosure
I just need to find a way to waterproof the wires hole
Second, I dropped the idea of 10S10P, too bulky, instead if need a will plug a range extender directly on the charge port like @skatardude10 did
I have a old 10S3P made of NCR18650B that will become a 7S4P to power the boost converter
Or alternatively put a XT60 somewhere on top of the deck to directly connect another battery, the only problem I can see with this is accidentally connecting a battery with a different voltage
I just wanna make sure that will be cheaper by sending the design for a few local manufacturers, if I order these ones there’s still need to send them for a machine shop to make a few modifications that will add to the cost
There’s a few that I need to think, any input is appreciated
1- If all sealing is well designed, the only remaining point for the oil to scape is through the motor bearing, if needed I plan to swap them with rubber sealed ones
2- the losses of the seal according to this diagram from SKF is way too high and would defeat one of the main goals I had going gear drive, 100W loss on each drive is simply not acceptable
As I suspected the geometry of TB trucks were quite different from the model I had downloaded, there’s only two flat faces on the hanger, the board side has a really small curvature that needs to be considered if you want a perfect fit with the mount
Also the baseplate is completely different in a good way, since the pivot is farther out, you get more clearance between the motors and the bolts, but the hanger body is wider, and because of that I had to mount the motor a little bit lower
I still need to check if the axle is in the right place since the small curvature makes it a paint to measure
Forgot to post the top speed simulation for the geared drive
(Click to open full resolutuion image)
With Gummies:
With Urban Treads:
Note that this is with 10S5P, my current 10S3P will perform a bit worse
My biggest fear is to overheat the motors when using the 6,5" wheels with this gear ratio, probably will install a NTC in them just to be safe and also convert them back to sensored
The gear drive is designed to work with 63mm motors, just need a new plate and a new 3D printed case
First changed the truck fixture so there is a part of it that mates with the lase cut steel plate to guarantee a better alignment
Second, now the wheel adapter is one piece, this way the steel spacer can be smaller and lighter, but the main purpose is so I can easily adjust how much compression there is in the sealing o-ring
The sealing works likes this. when you tighten the wheel it pushes the gear assembly, that pushes the bearing and compress the o-ring so no oil can leak when the board is running or when it is sideways, I highlighted it in the third photo
