Hi all!! This esk8 thing totally disturbed my mind and all I do day in day out this last month is reading on this forum and planning for my first build… Did some skateboarding about 30 years ago, but no longboarding experience. Can’t wait to be on a skateboard again though!
I’m in my early 40s, student with family, trying to figure out how to manage with this build and still put food on the table for my three girls.
I’ll use the deck mostly for daily commuting ~ 8-10 km / day. One steeper 100m climb, but mostly flat. I weigh around 80 kg, that is 170+ lbs. Yes, I’m European and go with the metric system I’d definately take torque over speed. 35 km/h top speed is good enough if torque is good. Limited to single drive though due to limited funds…
This is roughly what I have in mind for the build;
The trickier stuff;
Deck - Around 36" x 10" with some mild concave, stiff, but model/brandwise no idea. Seen a lot of boards in online shops and builds that look good. Scared of wheel-bite and not sure what would work with my 97 mms without using 4" risers. Any tips in the sub $100 range would be greatly appreciated!!
Motor - One of my -biggest concerns- - 6374 sensored 170 kv is what I have in mind, sealed would be nice and 8mm shaft would be good. Quality would be a plus of course. Can’t seem to find one though. Want it to be strong enough to give good torque with my setup - start from stand still without push, make that one steep climb. Thoughts and/or tips?
Motor mount - interested in @WSB’s “stealth motor mounts” if they’ll become available again.
Drive pulleys/ belt - 14 or 15T / 40T from @Titoxd10001 and 15 mm belt (if there is room)
Battery - Aim is 10s4p 18650. Not sure if 25R is good enough or maybe 30q. One day I see myself soldering, next day I’m getting an Arduino spot welder… So many options…
The less tricky stuff;
Trucks - Caliber II 50 10" - probably not so tricky…
Wheels - OG ABEC Flywheels 97 mm 75a - on their way to me. Only part I’ve $$ for so far.
A reliable BMS for charge and discharge.
EU built VESC
I’d like to get a Benchwheel remote, but hard to find at an ok price IF you find one, right?
Pull out spark plug. No fancy LED switches.
Some input on this setup maybe?
