The ESC is of interest what’s going on there? Hubs design is great for keeping the weight down but why so many P in the pack, surely a 7/8P would prove the point or is it to have long range as well?
A separate smaller P lipo pack for the speed challenge?
That’s a lot of power for a 7/8P pack. He will have too much voltage sag.
If it was me though I would go with Lipos, you can get a lot more current out of them and if you are not looking for range, going with Lipos will shave a lot of weight.
The target is the NXT record. They utilize a number of factors to get that record, pro DH skater, light weight, controlled conditions
This is a different approach & realistically who knows? but I would be concerned that it is akin to trying to get a speed record out of a muscle car, mind yourself!
I mean dude really?
Is a picasso painting a toy because it’s not a tool?
Hearing you call someone’s esk8 a toy because it’s not as practical as yours sounds hypocritical but then again I guess we should all just relax and enjoy this hobby however we see fit.
yea if you fall off right after the speed sensor going for the record, or maybe he fell off even at the speed sensor, that seems an invalid result. Im surprised guiness records accepted it.
I think moe came off at like 50mph with a crazy rear truck speed wobble, or maybe he was faster. there’s great video of it somewhere filled by bigboytoys I think
Considered going for LiPo packs but decided against it.
Going by the maximum current i would need at least 3500mah 50C per motor, more realistic is something like
https://hobbyking.com/en_us/turnigy-nano-tech-4500mah-5s-35-70c-lipo-pack-xt-60.html with 4 of them wired in series for each motor. It means total of 16, meaning 9 kgs of battery for 18AH capacity.
16 Pcs of 65E each + shitload of connectors costs same as 18650 pack.
Could not go with one pack per board bencause it would not support the current. Packs are terminated with XT90 plugs which is barely acceptable for a single wheel. With my pack i go with XT150 and 6mm2 wires per each ESC.Afer the connector there is a capacitor bank, wiring between capacitor bank and ESC will be 16mm2. Output wiring also 10 or 16mm2 not decided yet.
With LIion i get 40AH at 12,5 kgs.
If i went hardcore for 2000mah 100c packs it would be lighter but with little usable range, only good for maximum acceleration test at 7 kgs lighter. Cost again same as 18650.
Cycle life is another beast - lipo gets 100 cycles, HG2 gets 600 cycles at 20 amps to 80% capacity.
At the smaller capacity i would go through the cycles twice as fast, meaning hg2 is 10x more durable than lipo.
Charging the packs would be a nightmare, with 16 packs to charge and balance. This is after you get them out of the board. Each frigging time.
So i went with liion 18650, 20700 have smaller energy and power per unit of weight (for now).
13P is the result of battery layout under the deck. If i went with 2 layers of cells it would be 9P which is too small - at max current each cell would get 60 amps, sag would be a problem. 3 layers let me fit 13 cells in pararel, which tops at 40 amps per cell, good enough.
@MoeStooge
Speakig the truth i am in awe of what you accomplished already. Your creation is faster than existing record and after sorting wobbling it will get even faster. Perhaps even 150 Kph.
You got there utilising conventional, orthodox methods improved steadily over decades. It is based on existing, high quality components. It is the safest approach and will yield good results over time, no discussion about it.
My approach is throwing everything we know out of the window and starting form scratch with little knowledge about downhill speed skating and no experience. There exist no components meeting my criteria so i make my own, based on every bit of knowledge i can piece together to make some sense.
I am 99% certain that my build will get to 100Kph safely. It is sturdier, stiffer and heavier than the board that i took to 70 Kph. After that there is a barren land, waiting for the first explorers to get there.
I am 100% certain that my build will get speed wobble. Question is “at what speed”. And how to move this limit forward.
My project will end big. All i do not know is whether it will be a big crash or a big record.
