@Namasaki took my board to the next level by hooking me up with his 10s Lipo w/BMS set up along with addition of the newly aquired FOCbox’s.
I started with a poor 6s multistar battery that I actually broke on our first ride. I had to kick to get back and was pleasantly surprised how easy it was with minimal drag from the Carvon V2.0’s. @Namasaki was kind enough to let me ride his board that day and it put me on the ground escaping with only a nice knee scrape and some pant holes. I knew immediately my board was not complete.
The Images:
I just use nutserts/rivnuts and mount the bolt from the top and nut on the bottom,less pressure on the enclosure, you could even throw a washer on there before the nut to hold the weight of the enclosure better!
Just gives me easy access if I need to get in to the enclosure should something fail,a connection come’s loose or something over heats!
