Thought jet make a jet potato thatās a spud with a tale ā¦
I wish eBoostedās enclosure was juuuust a bit deeper for the Spud using the BKB 11s3p kit battery. Even with the foam edging Iām having trouble getting it to seal
Did yuu try with a gasket? Itās call like gasket d shape. Yup find for cheap on Ali anche give you up to 5-6 mm plus great sealing.
Danm really? is it the sides having trouble closing? I have yet to do a clamp test but from what I see so far i thought it would close no problem
is it the concave getting in the way?
Yeah, it seems that is the curvature of the deck that is touching the center of the battery. I havenāt velcroād it down yet either, which may add another 1-2mm. I may try to sand down the bottom of the deck just a hair to flatten it where it makes contact w/ the battery. Iām fairly lightweight so Iām not too worried about flex
The measurement is with velcro so about 21-22mm tall.
How thick neoprene were you using? Iām thinking of looking at other soundproof foam since neoprene is flammable. Iām also thinking of getting that P-stylle Gasket! Itās perfect.
Iāll take a measurement tonight. BKB sent it along with the enclosure/battery kit. Iām guessing itās 5mm?
I just finished the Tayto build this weekend and ran into the same issue. Sorry! These are the little kinks that I wanted to get worked out in the ābeta kitsā. This is the stuff I ended up using, its a few mm thicker and it seals up nicely. You can get it for like $3 at Home Depot, or I can send you some from the roll I have. You can probably even get a little bit thicker one as well.
Yes exactly. Worst case scenario adesive foam for sealing on one side and gasket on the other. You will get up to 1 cm for sure.
Do you still have them in stock ? BTW. Where are you based ? CALI ? Also ā¦you donāt have any eboosted enclosures left do you ? Also ā¦is Tayto in stock ? and also ā¦is the double stack eboosted enclosure going to fit Tayto ?
Yes the Spud is still in stock. I am based in Pennsylvania, USA.
The Tayto is on pre-order. Both eboosted spud enclosure (single and double stack) will fit the tayto. They will be in stock today (enclosures)
No lie, It took me a while to decide if I should wait for the Tayto or get the Spud now. I am without a board now since I have a hairline fracture in my main board. Stupid crap! It sucks to wait though, but it is what it is!
Awesome ā¦I think Iād place an order for either the spud or tayto with the double stack enclosure. I need something super small for short quick commutes.
Hello @JLabs, i just pre order the tayto and iām asking if you gonna sell again the enclosure + battery kit ?.
Not yet Iāve called three times and sent emailsā¦ Iād switch manufacturers if they didnāt own the deck mold.
They eventually send them but I donāt have a firm date yet. I only got an email a few weeks ago about them being delayed, nothing since then unfortunately
No worries. Thanks for being transperent.
Blows my mind apart that these companies donāt want to sell products
