Looks really good!! What do you plan on doing with your enclosures?
I want to make them a little slimmer, since thereās too much space left
that board looks legit man awesome job.
The sensored motors are in the house! Now I just need 18t 15mm pulleys with 8mm bore, since these has a lower kv.
Ty @BoostedBuilder!
Noob question here, but what would be an advantage of sensored motors be? Loving the build, looks stunning!
Better startup torque / smoother startup / no need for a kick push / FOC.
Do you have a link for the belt cover?
Not exclusively on sensored motors Sorry to revive this lol
True, but FOC does perform better with sensored motors.
Better how?
Benjamin Vedder designed the VESC for sensorless operation. As far as I know, that was his main goal. And I think he achieved it, quite well actually. So obviously, itās not much different in FOC. You donāt need sensors to run FOC using a VESC. It will perform just as great. However sensors help, at least me. I notice less cogging on start up, my motors heat up less with sensors, and I just have an overall better experience. Sensors sense the position of the rotor can in relation to the coils, so no matter how well the VESC was designed, they help, even if itās just the slightest bit.
Also, this is @fraannk 's build thread so letās stay on topic : )
I LIKE UPDATES
So I never got around to install these sexy new sensored motors from @BoostedBuilder , but nowās the time since I finally got my pulleys!
New motors are approx. 186kv, so I installed 18t motor pulleys (combined with the existing 36t wheel pulley) to make my top speed 44km/h. I also printed a new battery enclosure as well as new motor covers to fit the new Caguamas.
I also installed a new, more robust button, and most importantly, I redid the entire charging solution. It is still a two connector design, but it is now much cleaner and much smaller. The cable used for this solution was also re-made from scratch. It is now a combined, soft cable that works really nicely.
Details such as red countersunk screw washers was added, all credits go to @Deckoz for the inspiration. Board now runs in sensored FOC and runs like a dream. Itās safe to say, that I do not have any more upgrades/changes I want to do to this board. I only need a solution for lights, but thatās not so important yet.
Thanks for following! fraannk
How did you get the motor covers to look so well? Did you dremel them?
I modified the STL to fit the bigger circumference of the Caguamas. Then printed, then painted. EDIT: Get them on my thingiverse: https://www.thingiverse.com/thing:3091546
Awesome thanks man! , what program did you use to modify the stl file? I tired autodesk to modify for 90mms but when i converted it to a meshā¦ lets jsut say a macbook air couldnt handle it.
I used Autodesk Inventor in Boot Camp Imported the STL, converted it to a base feature, and then cut away the excess material with the extrusion tool.
Thank man man, been going mad with a way to modify that stl file. Thank you!
That is a mighty fine looking Vanguard build sir.
