45-50 to 20-15 on the back I can see the height difference, it isn’t too noticable though when riding
Ahhhh that is a decent difference for sure. I wonder if it is a 1/4" risers territory to correct for
no… someone needs to build adjustable baseplate with axles as center of pivot
I have thought about that too! And then quickly realized I am no engineer.
I am sure if we made enough noise someone will make it
I have vids of it when its still running on the trampa carver deck. I’ll find time to start up a youtube account so I can link vids
TADA!
You can see the height difference with the split angles here
The riser would also help with ground clearance if you wished to rotate your mounts upwards, of course they look fine anyway
Integrate a brake light in the riser since it’s going to be thicc?
I am probably going to just go back to an even split. ESC will go to the top. I actually avoid risers like the plague I like being closer to the ground… without hitting stuff
