The AVIO Urethane Gear Drive
Introducing the Aortal Gear Drive:
https://goo.gl/forms/xms9KmjyYpWPvJ2j1
Dual%20Drive%20Render 650x500 Aortal%20Drive%20107mm%20Wheels_Front 650x500
Price:
$150.00 USD incl. Intl Shipping (TENTATIVE PRICE, expected to increase)
Specs:
  • 2.65 Gear Ratio (45:17)
  • Ability to accommodate 63xx Motors and 97mm wheels or larger.
  • Compatibility with Caliber ll styled trucks (A standard Caliber truck can fit a single drive with any 63xx motor while an E-Caliber truck or a TB218 truck can fit dual drives with 6355 (possibly 6374) motors)
  • CNC-ed T6061 Aluminium Motor Mount
  • CNC-ed POM [45T, Mod1.5, 15mm] Spur gears
  • EN34 Case Hardened Steel [17T, Mod 1.5, 15mm] Pinions (8mm Bore)
  • HP Jet Fusioned Nylon Gear Enclosure, Hangar Adapter & Wheel Adapter
  • NBR Rubber V-Ring used as the sealing method
  • PLA Bash-guard
Instructions:
Tools you will need:
  • Torque Wrench capable of 16Nm or greater with a size 4.0 Male Hex Bit
  • Size 4.0 Hex tool
  • Size 2.5 Hex tool
  • Loctite 638/648/680 or similar
  • Loctite 242/243 or similar
  • Gear Lubricant (Grease)
PICTURE OF TOOLS TO BE INCLUDED
The Aortal Gear Drive Kit includes:
  • 1x Aluminium Motor Mount
  • 1x Nylon Gear Enclosure
  • 1x Nylon Hangar Adapter
  • 1x Nylon Wheel Adapter
  • 1x POM 45T Spur Gear
  • 1x Steel 17T Pinion
  • 1x NBR VA-60 V-Ring
  • 2x 6706RS Bearings
  • 4x M8x30 Set Screws
  • 11x M3x10 Socket Head Screws If Bash-guard package is included:
  • 2x M3x10 Socket Head Screws
  • 1x PLA Bash-guard
PICTURE OF KIT TO BE INCLUDED
(Installing the Motor Mount):
  1. Take the hangar out of the truck baseplate.
  2. Slide the motor mount onto the hangar.
  3. Slide the hangar adapter onto the hangar.
  4. Slide a wheel (with bearings) onto the axle and tighten it. The hangar adapter should be firmly locked in place.
  5. Turn the hangar wheel side down and the motor mount should sit flush with the bearing adapter.
  6. Screw in 2 m8 set screws to the inner holes (the curved side) of the motor mount. Ensuring that the motor mount is flat, hand tighten the 2 m8 set screws.
  7. Check once more that the motor mount is flush with the hangar adapter. (This is crucial!)
  8. Incrementally tighten the 2 set m8 set screws to 16Nm each.
  9. Check again if the motor mount is flush (Have I not emphasized how important this is?)
  10. Screw in the remaining 2 m8 set screws into the motor mount holes and incrementally tighten them to 16Nm.
  11. Check to see if it’s flush once last time. I promise this is the last time! If it’s not flush, you’ll have to start over from step 6. If it is flush, in no particular order, remove each m8 screw, apply loctite 242/243 or similar, and screw and tighten it back in to 16Nm. You should only add or remove 1 m8 set screw at any one time.
(Installing the Motor & Pinion):
  1. Remote the wheel from the axle.
  2. Place the motor (NOT INCLUDED IN THE KIT) with the cable facing the board side onto the motor mount.
  3. Hand tighten the motor onto mount. (You should not be able to move it along the mount after.)
  4. Apply loctite 638/648/680 onto the motor shaft and slide the pinion onto the motor shaft.
  5. Use the 3d-printed washer provided to ensure the a 1.5mm gap between the motor mount and the pinion.
  6. Let it sure for a minimum of 30minutes before continuing with the installation process.
(Installing the Spur Gear):
  1. Lightly loosen the motor from the motor mount so you can slide it along the motor mount but not so much till the point where you can rattle the motor.
  2. Push the motor away from the truck.
  3. Place both 6706RS bearings into the spur gear.
  4. Push the spur gear to the end of the bearing adapter.
(Adjusting the Backlash):
  1. Using a piece of 70 to 80gsm paper (standard notebook paper), fold it in 2 and place it inbetween the spur gear and the pinion.
  2. Slide the pinion along the motor mount such that it forms a tight mesh with the spur gear and hand tighten the 2 motor screws furthest from the spur gear.
  3. Rotate the pinion or the spur until the piece of paper rolls out.
  4. Remove the spur gear from the bearing adapter.
  5. Tighten the remaining 2 motor screws.
  6. Similar to step 11, tighten all 4 motor screws to 6Nm each, with loctite 242/243 or similar.
(Installing the Wheel Adapter):
  1. Screw in 6 M3X10MM screws into the flywheel adapter.
  2. Place the flywheel adapter into the core of a wheel. (Ensure you,'re putting it on the correct side of the wheel, it should be the side closest to the bushings when you slide the wheel in.)
  3. Wrap the V-ring around the adapter and ensure it’s flush with the wheel.
  4. Carefully place the spur gear back onto the hangar adapter (the side with the larger holes must be facing you, away from the motor mount), ensuring it meshes nicely with the pinion. (Give it a quick turn to make sure it spins well).
  5. Apply your lubricant of choice to the spur gear and pinion at this stage, making sure both the pinion and the spur gear are coated thoroughly.
  6. Using 5 m3x10mm screws, secure the gear enclosure onto the motor mount.
  7. Remove the wheel adapter from the wheel while ensuring that you do not to move the position of the v-ring.
  8. Attach the flywheel adapter onto the spur gear by aligning the 6 holes of the spur gear with the 6 m3 socket heads.
  9. Install your wheels on the axle just like you would any regular wheel, aligning the spokes on the wheel adapter to the holes of your wheel core and tighten it. (Don’t forget your speed rings!)
  10. If you purchased a bashguard, install it with the m3 screws provided into the following holes.
  11. Voila! You’re done! :smile:
How many will you be willing to purchase?
  • One
  • Two
  • More than Wwo
0 voters
Turntable 650x500
IMG_20181019_143846
I’ve tested my gear drive to the extent where I think it works well enough to be sold to the DIY community. I’d say that these are still in the prototyping phase and the price that it’s sold at reflects this.
More information on the testing process and updates on it are shared in post #55 and is tagged below as the solution to the thread.
Looks great!
What kind of gearing options would you offer, If none would the gear drive work with 90mm wheels and still have OK ground clearance?
That looks amazing.
As of now, it has a 2.65 gear ratio and is designed to work with 97 and 107mm wheels. I can probably get it smaller to work with 90mm wheels :smiley:
I assume single drive? Unless you’re making magic happen :smiley:
Are the actual gears plastic? Personally I wouldn’t want plastic gearing without a belt. A friend of mine had broken/worn gears in a short time. After seeing that I’m not so sure.
But your design looks awesome.
IMG_20180825_133738
IMG_20180825_133529
@UKRider
I can only assume you are living in a bubble & as per your limited forum experience you have done no forum research? steel/pom gear combos have proven to work quite well in rc/eSk8!
You see I got a high kv motor. So just a low gearing would work great for me. 97 - 107 for regular motors 170-205 kv And for peeps like me with a 245kv I would put on a 90mm.
So the new question is ignoring 'comfortable gearing ratios etc, Would 90mm wheels work with the drive?
@brenternet Yup! It’ll be a single drive on a standard caliber 184mm. I have another version for the extended caliber trucks and the tb218, just gotta invert the mount. :smiley:
@UKRider They’re CNCed from POM, yes a kind of plastic. I’m not sure what material those gears of yours are made off, but people in this forum have been using the combination of steel and POM with good results!
@Blitz I tend to go bigger on my wheels and have a lower KV on my motors simply because of the riding comfort i get from 97mm wheels and above. If i do decide to sell these, i’ll definitely try to design it to accomodate 90mm wheels (I think it’s very possible tbh, but i wont know till I re-design the mount and enclosure.)
No need to get so sensitive. Only stating what I have seen. Everyone has there own preferences, Gears only, belts, hubs and so on.
I actually like the look of gears.
Redesigned it a little to accommodate smaller wheels (97mms) better (chopped off the end by 5mm to give it better ground clearance). With this current gear setup (Module 1.5), I don’t think i can get it any smaller to fit 90mm wheels.
Gear_Caliber_Mount_2018-Sep-10_06-53-23AM-000_CustomizedView16432058468 Gear_Caliber_Mount_2018-Sep-10_06-53-55AM-000_CustomizedView4646797648
Will now have the option to put in my Kegel-core wheels! :smiley: Probably going to be trying them Boas on this.
Kegel%20Gear%20Drive
Don’t think module 1.5 is a good choice, everyone else uses mod2
actually lots of people are using down to mod1, it’s all about sizes, contact and meshing.
Oh ok… Who have you seen use mod1?
I know @MoeStooge have been using Mod 0.8
Ok sorry didn’t know
Yeah but he’s hardly pushing his board to the limit is he /s
Mod.8 32p https://youtu.be/cukkNbBSQmQ
Yep my bad, I guess I forget
