No worries lol. Fully knowledgeable in what I’m doing. Now to get the esc programmed. Hopefully can have it running by tonight. Hopefully.
LoL I sent him this when I saw it
Before he told me the heatshrink was clear
I also almost had heart attack when I saw that photo
Joker is the name and I’ll be here all week.
Are the tabs going to be able to handle any flex to the deck? Can they be rotated to some degree to prevent bending from flex?
Okay, so basically this is the plan. Once you have 10 modules in place, solder and join the tabs using a 10 gauge flexible silicone wire/ braided copper wire. Then you fold all the tabs into the form shown.
The flexible silicone wire should provide all the flex necessary.
So it is not going to be completely solderless in its present state.
Also, I forgot to put the standoffs and the bolts in the render
@Kug3lis I see what you’re saying – a propeller in the front and a propeller in the back! Right? Right? Please say yes
The only thing better than a leg-chopper on your longboard, is two leg-choppers on your longboard
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7086?u=skunk What mm are those wheels?
85mm Orangatang blue Caguamas 77a
Wanting to put 97mm on my moonshine if i can
100mm boas looked pretty bad.
Check my build thread:
Man this 100mm look much bigger than my 97mm. Maybe ill use the 90mm abecs i have
How long is that deck?
35x9 i think
Boom
Thanks, but its way too big
too beaucoup?
How about 34.
