You are incredibly lucky. Could have been bad, real bad.
While it was charging presumably? Do you have any pictures of where you thinknit happened, like during your build process?
No, not while charging. It was unplugged and no anti-spark plug. One of the batteries went bad. And wouldn’t charge.
was it lipo?
holy hell, seeing these fires regularly now, i’m ordering a fire extinguisher right now.
I know right?!? I need a snaller one in my backpack, I have a big ass regular one at the house, but damn.
me too and I’m tempted to go design a battery with ejector system
YES! Me too. I am thinking of a fixed hinge (on two sides of enclosure, with no hinge-action) with a “rip-cord” attached to the deadbolt(s) so if necessary the pack can be jettisoned to save the board. great minds dot dot dot…
After soldering the wires onto the pins, I applied a small amount of silicone in between the two inner black plastic bits that hold the connector in place and then used heatshrink with a glue lining instead of the outer plastic part. Should hopefully make it pretty watertight.
Looks pretty good! There is a waterproof version of it too https://m.ru.aliexpress.com/item/32850103487.html?pid=808_0004_0101&spm=a2g0n.search-amp.list.32850103487&
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/6256?u=battosaii @3DServisas what are those!?
Awesome they have been sold out I kinda want one even though I never has over heating issues.
You can pre-order one now, it’s sent to anodizing, should be back by the end of the week.
@Andy87 What are these called. I can’t read a word on the website. I’m mounting my focbox up top in @Kug3lis cnc case. These look perfect for what I was thinking
on the subject of pre-ordering how is the v1 drive coming along
Search for waterproof m12 plug on AliExpress
thank you sir
Follow the thread
