ahh okey hahaha…it looks not that bad for a budged board i think. Wowgo is pretty cheap so for some kids a very good option getting in touch with electric skateboards
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/520?u=arek Did you drop it or what?
It’s gear drive because it uses gears and thus is not direct drive.
yeah i would spell it the same way
No I received my batteries that way trying to get more sent from the seller.
hi gents, yes they are the Bergmeisters…I think the confusion comes from the Bergmeisters showing the “inside” facing rim side. The “promo shots” are just showing the outside facing side
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/527?u=grozniy New invention from Tony Stark? The spider-nickel filament, capable of 200A continuous
I think he’s using those as a fuse (melts when overloaded/shorted) and if a bigger ball of molten copper will be created and fall right between the positive and negative, it’s going to burn all.
It has a self destruction feature, you just don’t know when ehehhe
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/512?u=rusins
Nice dj controller
I was just listening to this in the back ground as white noise while I was laboring over a hot iron.
Goddamn it, my race pack is tainted/cursed. I had finished up serial connections and walked out to the bars at the end of this. Now I have doubts.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/544
Just need belts and to fit the enclosure… can almost smell the speed…
@Mikaelj just to update you on how the the mounts fit:
- Fit tighter than a nuns you know what!
- Can only fit 1 cross bar as it hits the hummie deck
- Had to use 110 shoulder bolts to marry motor pully with wheel pully on street wheel and AT wheels. 4 Snapped a bolt while trying to undo a truck mount (can you hook me up with another nut and bolt please)
These mounts are a dream, easy to instal and look the part… can’t wait to get this think on the tarmac
@Powadangaboards That’s what I call a sweet setup! Maybe you could update the whooshboards thread with some pics and specs? Those are the sealed maytec 6374 with the extra extruding part so they are longer than 74mm right?
Clamp bolts are A2 M6x25mm bolts from accu group. Should be easy to source. I can also send you new ones if you like.
Ill get some pics up in a sec, if you could send a couple of extra bolts that would be sweet
They are maytech sealed 6374 and they have plenty of room, i wonder if the maytech 6880 will fit
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/546?u=grozniy Sweet setup bro
In the gutter again @Sender? https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/534?u=banjaxxed
Feel like I live in a damn gutter!
RICH FOR THE SKY!
The sky’s the limit
