Impeccable design. Congratulations, 10/10
is that wire from the stator ? ho did you clean it ??
the enertion hubs look funny beside de new TB DD ! And you get them AWD !!!
the PU still sucks on the Raptor hubs. and yes I thought about it for a long time before ordering the 4wd TB DD. basically if I ever wants to build a 4WD it cannot be belt driven with reverse mounts sticking out at the front of the board, and I ride low so no motor under the board. the natural answer is DD or hubs but i already got all the good hubs.
I join you on that thought !
you will make a build log ?!
don’t know what to put them on yet. so are the other drives. Lmao
- small dual 5055 will be on my old Bustin Ibach 37
- Surf Rodz probably on MovE
- Raptor will go back on my Hyperbeast
- Nano drive probably on the Tayto
Can you take a pic of the raptors next to the TB drives? Should give an interesting perspective.
And a unassembled hummie hub
I’ll can take a picture of the TB DD next to Elofty when I swing by @sofu’s tmr. I know for sure that these are way bigger.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/331?u=rusins
I’m pretty sure this stuff is too nice for you. You better send it to me for safe keeping.
back to my home city I will bring it over one day when I decide to go back to visit. half my fam is still there so many chances.
Its not my board it’s there NYC ambassadors the board is nice tho.
So many drivetrains and no builds?
You damn hog.
He’s gathering presents for upcoming Secret Santa
He selling the deck yet?
15550862277747034610728811747952|375x500 Hey Guys. I’ve a little problem. I dont know where i should solder the negative and the positiv wires. (its a only charge bms.) Does that mean that I only have to solder the charging wires on it?
You only solder the negative on it.
Bottom left to negative battery. Middle right to negative charge plug. Then only positive batt to positive charge plug.
Okay, thanks for your answer, but i already finished it:wink:
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/262?u=arek That looks like enough for second sk8…
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/347?u=sender
@Therealesk8, Jonas.
You have a tendency to double post and generally over post in the picture thread. Like a lot.
You can put multiple pictures in one post. Also, you can start a build thread and put more often picture updates there.
Just a friendly suggestion.
Cheers!
Sry, i didn’t know that.
