https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/314?u=rusins Holy balls that is cool! It didn’t even occur to me that the thickness of the Hummie deck had such an upside! You might have just convinced me to use my Hummie deck for my AT build after all; I can imagine using RGB strips and an Arduino to have 1 side flash orange when making a turn
Yeah love this board for AT ! My led strips are controlled by my remote. Push a button and I got headlights and brake lights.
Thanks for that, I was having a hard time imagining how a strip would look
It looks amazing, just need to buy some of the waterproof ones
Do you plan to do the same at the front? Don’t know if it would light the road enough
Yes , I’ve got white for the headlights just haven’t put them on yet. They’re pretty bright at 12v , for me I just wanted to be more visible to others.
I think it needs a “my other golf cart is a skateboard” sticker
I though they were the adressable ones (ws2812)
I will try on mine this weekend, if it works I will get the 144 leds/m version
Ooooo what is that and where can i buy some?
@moon https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/292?u=battosaii
Kegel hub adapters for my gear drive or pulleys. Submitted the order like a month ago and during that time we discovered that tb wheels are flipped.
I only made these just to test the concept and probably sell most of them for really cheap
Can probably solve the flipped kegel problem. Ive asked them if I can make new shafts.
Those pillars you see are removable so it should be possible.
Also I want to make a single hub adapter that works for kegel and flywheel - but that wasn’t really a thought a month ago
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/331?u=rusins
Looks like you’re having clearance problems? Why not mount the trucks in drop-through fashion?
Lol not at all friend, just holding them up for color reference. They are adjustable to a ton of positions
Still raining? Have you had a chance to test drive the board. What battery size did you go with?
No rain, but unfortunately the battery I was sent by Torqueboards only charges to 46.2v which makes it a 11S4P instead of 12S. Will have to put the board test on hold until I can get a working 12S battery in abit.
56.2/4.2 is something like 13.5?
that cant be correct or else your over charging?
12s should be 50.4, 11s would be 46.2
Take it easy on the noob. He’s just starting out!
Ok Ok Ill Chill out
46.2v sorry. Yikes…
Tried with 2 different 12s chargers but no go. Thought it was the battery indicator programmed for 11S but the Unity was showing 46V so something wrong with a P group or BMS connection. Have to send it back for repairs, currently waiting on an RMA but ordered another battery in the meanwhile so I can get this board up and running.
Ok probably a shitty P group, Hopefully you can get it fixed
That’s gonna be awesome. Can’t wait to see more!
