Roadrunner Powerslide
Nope, but on my list of things to try
Cool, I’ll take your tb110s when you switch them out
I don’t think so, he’ll put some metal studs to ride on ice
I rode on ice earlier on the TB110 and boy, it’s slick as snot. Can’t wait for spring
MBS fivestar
The blue skirt I would do
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9589?u=sender
@Chupacabra looking awesome!
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9591?u=wraith @Riako I wasn’t aware that those gear drives were compatible with haggy hubs!
It is not supposed to, but, I have to make it ! The mini Gear Drive is maybe more indicate for AT wheels, but I will test it with this 10mm W gear.
Did you CNC the wheel gear for it to be compatible with the 3 spoke hub? I’ve got the 1:3 gear drive for tb218 and would be awesome to have the option to try the haggy wheels
No, I use the one included : (print prototype) And the new adapter in AL7075 :
Your 3:1 wheel gear also had 6 screws holes I guess ? But not sure if it’s the same diameter as I’m with the Nano (2.6:1, I suppose Yes just yours are 14mm wild true ?)
But I think it will work even more perfectly
yup 6 holes and larger but not sure of the diameter. haven’t measured it yet
I’m working on it ok jks
Nah, pneumatics. theyre not mounted on a 30” atm, will see if I have time within the next days.
thx your all right !!
It was a scary moment when my car did a 180° in the middle of the expressway. It’s all good though. No one was hurt. Just a fender bender. I collided into a tow truck and a cop pulled over and had 3 cars collide into him. It’s was slippery as f out there.
Holy hell! Glad you are ok!
