With esk8, every failure, however improbable, seems to somehow be possible…
That’s insane man, I’ve bent a TB mount but honestly I would has been better off if it broke like yours maybe I wouldn’t have been thrown off as bad.
Also. Is that a spud with tkp surfrodz?
Yeah I didn’t get thrown off, I landed the jump and then used the throttle, no response.
Heck yeah it is! With the freebord bindings too, it’s crazy how stable it is at speed while having like a 5 foot turning radius.
Ive got something very similar in the works. Bindings and all
Its amazing how well it works, jumping up curbs takes some getting used to but its surprisingly easy after the first few times. Make sure you get some riptide bushings in there though
Not anymore. I moved and it didn’t make it lol. I’m sure it would help though. I gotta remember how to use the builtin leveler. I was tweaking it while it was printing to make sure all the lines were the same thickness though.
Ah;;;; As expected, the beer was sprayed with fractions. Shake it…shake it…
@linsus https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9437?u=andy87 Where you got them from?
I think they are on endless sphere
I have seen them already somewhere else but I can’t remember.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9446?u=riako
be careful, he’ll steal your title!
I think you need to be locked up for showing that much sexy board porn
A wonderful idea! Only one doubt. Does not the jack knife phenomenon be caused by sudden braking? Does the trailer slide sideways when running downhill brake or weak grip road?
If the trailer is light enough to easily move the load, a jack knife phenomenon can occur. However, fishtail phenomenon caused by excessive speed is more problematic.
found em on aliexpress, took 5 days to get em. Can recommend!
@linsus is the space between the cells such that you can run the balance wires down the middle of the pack with fishpaper on both sides?
Thank you for answering. The idea of this trailer changed the conventional concept of putting a large number of cells in the enclosure.
