Phase wires and Sensor cable (without need to remove the JST Plug). Can trim the extension to suit so it meets up with enclosure.
This is a revised version of what I’ve have on my board all year. Works great and keeps everthing neat and tidy. Printed one for another member on here and it turned out the holes on his drop through deck were different to my top mount one, and I hadn’t made provision for that on the design. Today I went back to the project and made some changes and improvements.
Can we get files for printing or buy from you? This would look great on my build.
I would suggest splitting the “main section” from the “tunnel section” so you can print one in petg and one in TPU. My deck has a curve the tunnel would have to wrap around.
I’m not a vendor, just a hobbyist The files for any of the stuff I’ve doodled are up on Thingiverse. Just search Toughook Riser, or Enclosure and it’ll come up.
My deck also has a slight drop through and the ‘tunnel’ flexes easily because it’s only a couple of mm thick. I could easily do a seperate file for just the riser next week if you wanted ?
It’s a 2.5mm part. Printed vertically up. The parts are supposed to be glued together with epoxy in between.
In my next enclosure, I am going to print the parts very thin and then reinforce it with fiberglass sheets and epoxy.
I am also thinking of creating a thread where people can seend me a cad model of their deck or just enclosure dimensions and I should be able to churn them out pretty fast because the models are parametric.
