I know. One of the rear wheels is like that too. I have not turned the tire around yet because I’d have to remove the pulley that’s screwed in with locktite. I’ll fix them when I change wheels again. I have my street wheels on right now.
Just a 10S 2P 12Ah auxiliary battery for range extension (approx. 30km more)
do you have this hooked up to a step up converter?
yeah -this one set to 42V 6A
As it is they are pretty heavy, but they will machined to fit a bearing, I can see in the CAD tomorrow the final weight
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7362?u=grozniy Nice looking. What tire will it accommodate? What pulley is compatible? Price?
@brenternet https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7364?u=mmaner
Besides being a good ay to get shot in practically any major US city, whats going on here ? Is this real or what?
Gummies to 8 inch Any pulley designed for superstar will work Price around $50 per Hub, will include axles to replace the stock on ultimate trucks.
Aluminum 7075-T6 Bearing 6200-2RS 10 mm Axle included, Hardened Stainless Steel
Straight from the man himself.
Nice! Exactly the price I wrote on Instagram i thought it’s going to be But how to change the axle? I thought they pressed in the hanger?
It can be change using a torch I can make a how to post
The issue is Trampa bearings keep dying like crazy and make no sense to keep using those
Sexy as fµçk brooo !!!
80100 and 8085 for comparison
Absolutely ridiculous! On what trucks? Infinity or mini’s? And which aps motors are they?
Vertigo 80100 180kv but they fcked up bit with custom shaft we ordered…
