It is a deep single, but you could surely fit 1.5 in there with a thick weather strip.
Please throw that remote into the trash can
lol if he is using that remote it means that he is using the shitty esc to right
No, it can be the winning remote. Which is usable with vesc
true but i use 2x VESC
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9515?u=mich21050 Nice blynk interface… only problem is that it won’t work when you are not within your home wifi… (I think)…
It won’t work when the charger is not within my home wifi (which will almost never be the case). The phone will still show the correct values even if it’s not within my home wifi as long as it has internet connection.
Yeah you would have to hardcode any possible wifi network within the esp8266 or that it creates a hotspot every time it boots up so you can select to which wifi network it should connect…
But you know way more than I do so… Thank you again (for your help)
Right, but this won’t go into the board enclosure. This will be a part of an external BMS charger. The primary responsibility of the esp8266 is to show data on the TFT display. The Blynk part is just a bonus (it has wifi so I must use it! ) . I wouldn’t bother with it if it wasn’t so easy to setup with Blynk. It’s still nice that I get a notification on the phone once the battery is charged… even if outside of home (not that I really plan to ever charge my battery unattended) or I can check how the charging is going without getting up from my sofa (cuz that’s important ) .
Now you only need to build a robot arm which can disconnect the charger automatically… Any plans on releasing the source code? I would really be interested how it works… Ok sorry…
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9516?u=b264
Maybe we should make a DIY Inboard battery mount and just use their $99 batteries LoLz
The current state of the code is a bit of a mess, but if you’d like to take a look, here it is: https://gist.github.com/janpom/9bd20d4c0887847d628b18a05e2fd7eb
Not a bad price for certain kind of rides.
I’m wondering what board they are working on. I think a larger battery cutout with the same plug would be awesome. Backwards compatible with the 97wh battery from M1 for travel and larger battery for those that don’t travel
That will be my v2. I should still be able to control the charge circuit MOSFET remotely, which is close enough.
@skatardude10 what happened? Looks close to nuclear meltdown.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9420?u=lrdesigns
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9518?u=yelnats8j
I used to go to these all the time as a kid so much stuff going on could tell what the hell was happening
Yup. The boys are wicked overwhelmed.
Hell, makes my PTSD twitch a bit for sure. Ready to shoot a bitch.
If we could get this but with 6 larger pins and 12 smaller pins it would be perfect for enclosures on a dual setup
