I know this topic has been posted before as I have done a lot of searching on the forum, however I need an enclosure for just a vesc without batteries. I can’t seem to find any that are the right size. I don’t even need a custom one, just maybe a suggestion on a cheap Tupperware container or something of that sort.
I saw that but is there a cover or something?
I don’t want it to be uncovered
I could probably make one pretty easily, or you could use a piece of heat formed ABS.
I don’t have a 3d printer.
I wish I did
Depending on the cost of printing I may have had it printed for me but if it doesn’t have a cover then I don’t know if I would do it. However, it does look cool
I don’t mind using a container or plant saucer or what not, I just don’t know where to find the right size
I think he wants an enclosure and not a case
cool be right
Right on 10 charc
Try collections/battery-enclosures
They have an esc enclosure for their 12s esc not the vesc and it’s ridiculously expensive
They have a blemished version that’s cheap if you look in there.
Yeah I know but it’s for their 12s esc
Alright gotta run for a few. Please keep posting and hopefully will be back soon. Thanks in advance!
I actually looked at that and was seriously considering it but I’m in the US and that’s EU
I bought the dual, its quality gear. It took awhile to get it and was a total PIA to get the new cap boards installed and make everything fit, but they end result is pretty awesome. I would suggest it if you want a VESC enclosure and cant find a vacuum formed ABS or fiberglass solution that fit your needs.
