googled E-glide and a Harley Davidson came up? you wanna do what?
Hi guys I read onloopās post about āCā output and why itās important however Iām still a bit confused.
Does a 6s 5ah 20C battery have enough max amps to power a 270kv motor? I think this means I have a max 100A output, but is that enough to move a 70kg person to the boards max speed? Or is it better if I get 30C?
Basically I have an e-glide 42 special and it has 3-12 volt batteries in series and it has an 800 watt motor, but for the control unit it has a board type deal itās not an esc, it has a wired controller. I was wondering if there was an esc out there that would work with the board in place of that little control unit.
aaah thats a chinese board okok So yeah, you could use a vesc instead of your control unit. Than buy a Mini Remote for wireless action and youĀ“re good to go
Itās. Made here in Santa Monica , California
Whats the name of the company? These are most likely importet and rebranded products. But that doesnĀ“t matter Try it with a Vesc
That board makes it incapable of having a wireless 2.4ghz remote which is what Iād like to accomplish
Canāt create a new topic so I guess ill just rant here
So, I built my board 18 days ago. Today I have a burned DRV
Specs: 10s3p Torqueboards 6355 190kv dual 4.12 Torqueboards VESCs
Iāve put 293 miles on this board in the past couple of weeks all has been fine and lovely. I go on lunch today, come back and as always - when I plug in I test motors and before I unplug I test motors at very low throttle. Anyway back from lunch get to my desk, test motors with a blip, fine. unplug work the rest of the day, goto leave, plug in, test motors, only one motor spins. DRV burnt out. I canāt understand why it would burn out from the time of unplugging to plugging back in.
@torqueboards this is about my last straw dealing with them -sent motors with incorrect barrels -antispark failed on first plugin(known issue) -now iāve got a dead vesc when nothing has changed lol -their edge retainer on the motor drive pulleys are lightly pressed in an fall off(basically theyāre cheap).
electric skateboard gods are killing my buzz right now.
My first E-board. 10s3p battery 6355 motor(dual) dual vesc gullwing sidewinder2 Alani lani carbon deck but. i donāt have anti spark switch. so i just want buy itā¦ please guide me.
nice lights use a xt90s loop key or a vedder antispark switch. Plenty of threads here on the forum how to do that
thanks for the help!!
Hi, Iām looking into making a cheap electric assisted penny board. I do not want an esc or transmitter or receiver. I plan on having a button on the board to give me a boost. what battery and motor should I buy. any other suggestions are also welcome. Thanks:slight_smile:
An ESC is responsible for sending power from the batteries to the motor you canāt skip on itā¦ the receiver/transmitter you can skip on and have a wired throttle control to the ESC but no ESC means no electronic speed control.
Your situation seems a bit custom. You should look into remoteless / weight sensing boards and so on. Also as suggested u still need esc to control the motor. Maybe @Ackmaniac can shed a quick reply for u to send.u in right direction.
My opinion: assist only might be a bit.hard. You could try to implement what @Ackmaniac has made by getting vesc and running it in mode where u need to kickpush to gain additional speed but.your board will.cruise at speed.it.has.reached.by your.āhumanā power
Alright thanks
U can get it but then u still need to buy vesc which will cost close to 100usd. Then u would install his.custom firmware and get this hybrid - assist.mode. hope that helps
It does thanks but unfortunately right now I donāt have 100 quid for a vesc
How would i add brakes to my board?
