Hey guys,
I was wondering about the use of the Space Cell for motors rated higher than 2400W. Description clearly says “rated for motors of 2400W or less”, but I already saw multiple people using them in combination with high-power SK3’s for example.
I’m not really worried about damaging the battery, since the VESC inbetween can limit the current to the desired amounts. I do get that you might not be able to use the full power specified for that motor, but will you be able to use the motor as efficiently as possible?
I already contacted multiple people, for example @elkick told me it would not be a problem although Enertion Support claimed "Space pro is designed for Enertion motors only. It has a 40A fuse and if the current draw is greater than that it will shut down as fuse will blow up. So, you cannot use it with 3000w"
(which seems to me like a bit of a sales pitch).
What do you guys think? Please let me know, thanks in advance!
