Hey everyone I’m new to the e-skate world, first off thanks for all the info I’ve been able to find here. I’m building, my first board and there is a question I haven’t been able to figure out regarding regenerative braking with a vesc and space cell. If you brake with a full charge in the space cell will it over charge the 18650 cells? My question arose when doing research on BMS’s and I noticed that most have a separate discharge lead than charge lead which means the mosfets only have a low voltage cutoff on the discharge and high voltage cutoff on the charge so they won’t shut off of when the regen is over charging the battery through the discharge lead. I was wondering if the space cell works around this problem with any of the following solutions:
–Regen current is redirected through the charge lead with diodes
–BMS is designed with high voltage cutoff on the discharge lead
–don’t break when your battery is above a certain percentage
well most likely you wont brake without first using a bit of power to get going also no it wont because u have a 40a fuse to prevent this from happening.
So I was originally thinking of going with LifePO4 38120s cells because of their stability and long life but the shipping from china was way too expensive so I will probably go with LiNiCoAlO2 18650 He2 cells which are on amazon and do a setup like the space cell with a BMS from Battery Supports. I’ve ordered a vesc from enertion and an SK3 from hobby king. I’ll cnc my own motor mount.
Do not worry about the regen current over charging your battery unless you start by going down hill from the get go. The regen current is not that big and the current fluctuates so the cell will push resist any charging that is not constant current at least in real world usage.
would regenerative breaking current destroy or damage an UBEC on the same power leads? I want to add and use a separate voltage for lights without having to resort to another battery…
Wrong, ive killed two ubecs. My situation was that the loop fell out while riding, so the power generated went only into my ubec. If you are only breaking normal and not trying to break down a monster hill im sure you will be fine, but if you pop the space cell fuse the power will still have somewhere to go.
In normal conditions the regen current do not damage the UBEC.
Your case is a battery system malfunction or user mistake.
@thisrealhuman I advice you read and analyze what you write before pressing reply. I prefer to comment just on issues I really understand. Don’t like to send people in the wrong direction.
