I’m Ordering these:
Sony Konion US18650VTC6 3120mAh - 30A
Brand: Sony Energy
Model: US18650VTC6
Nominal Capacity: 3000mAh
Nominal Voltage: 3.6V
Maximum Voltage: 4.2V
Discharge: 15A Maximum Continuous or 30A Maximum Continuous with 80C temperature cutoff
Positive: Flat
Protected: NO, UNPROTECTED
Rechargeable: Yes
Dimensions: 18.2mm x 64.9mm
Weight: 46.8g
would any one be interessted in some?
4.5$ + shipping US only they take about 30 days to get here.
According to nkon these also come with 3120mah so we’re pushing the envelope at almost the same price as q30’s.
These will go nice in my @Hummie decks with dual ESCape B-Boxes
I did many packs with konions. They are my absolute fav cells. High C rates and good capacity. On top of that their chemistry is one of the safest available for 18650 they do not disbalance and have a self balance tendence (more intense on v3 and v4) many builders use them without bms.
Mooch reviews are very good and we should read them but not take them as if they were written on stone. He is a VAPER 1s1p use.
It is true that vtc6 C decreases to only 15 amps at high temperatures and the capacity shortens a little after some intense use but that situation has Nothing to do with us. We do not use single cells at its full performance. Just by making 2p the temperature will never reach 80° and making 3 or 4p keeps the pack at nice warm temperatures.
I prefer konions over 30q not for the price but the performance. They are the best of the best for ev’s.
I’ve made well over 30 packs with Sony VT6 so far. Most of them 4p, some 5p. Anything over 5p I would recommend using 30q as they’re cheaper and that many in parallel is enough. 6p+ of the VT6 in parallel is just crazy overkill for most applications.
I’ve had one problem so far where a cell that died (must have been faulty) took out a whole 4p parallel pack as the user didn’t notice until it was too late. (Easily repaired though)
So apart from that, these cells have been rock solid, pack a massive punch and seem to last forever!
@rojitor is right, because we parallel them up, they never over temperature like the 30q tend to, so they’re always capable of 30A continuous, and my customers really feel it when their tons of torque kicks in
I highly recommend these cells. I’ve literally just bought £1400 worth of them!
