So one of my TB 6374 motors was having a retainer issues, luckily I had a spare one laying around… so I’m using custom motor plates on evolve trucks (with fixed motor positioning) … prior to the change my belts were evenly aligned at about the same exact tension (not using the idlers). After replacing the motor all of sudden one belt is super tight vs the other one, on the same side (tight) i had to slide that motor pulley further down than the other to be aligned properly … so I’m wondering what could’ve have changed?? I did an even swap of the motors with the same exact size & brand of motor… has any experienced this or have any possible solutions…wtf… note I adjusted and made sure they are perfectly even still the same…
