Hi,
Im selling two Two Turnigy D5035-125KV Sensored Brushless Motors. Spec is
KV: 125 Max current: 45A Max Power: 2000W Idle current: 0.9A Resistance: 90MΩ Shaft: 8mm Weight: 745g Suggested ESC: 220A VESC Cell count: 8~12s Lipoly (Voltage) Bolt holes spacing: 44mm Bolt thread: M4 Connection: 4.0 banana Gold plug Shaft length A (mm): 8 Length w/ hubs B w/o shaft (mm): 71 Can Diameter C (mm) 62.50 Can Length D(mm) 54.80 Total Length E with shaft (mm) 108.50
These are £77 each but looking for £60 each and will post for free if in the UK. These have been fitted and run for less than half a mile. Want to change my whole setup hence the sale.
Hobbyking link is https://hobbyking.com/en_us/dt6376-14p-sensored-motor-125kv.html
Thanks
