I have a couple brand new in the box ‘sk3’ 6374 motors for sale. I needed a few and I was under the MOQ. They are custom motors, Ive exclusively used these motors for 3 years now. They’re pretty much the most powerful outrunner you can get and they don’t look like shit
300mm sensor cables and phase cables
5.5mm phase bullets
10awg silicone wire
Extended 40mm shaft
8mm shaft dia
190kv
Jst mini 2.0 plug right into any vesc
I’m selling them for $100 plus shipping. I should have them in 3 weeks.
These sound really awesome! How much would it cost for one shipped to San Diego, California?
This would be for a single motor build with a 60kg rider, how do you think it would perform? Would the side pull be too much to control or super noticeable? I am also guessing that they do not have keyways in them? What do you use to attach the pulley to the shaft
I’ve been using a 6374 192KV for 6 months now, I’m 85kg with my gear but even when I was 97kg (my weight fluctuates because I fight competitively) the motor handled me fine though I’d need a lower gear ratio/second motor for very steep hills. Still, I see 32mph top speed regularly and I’d imagine you’d see more since you’re lighter.
My motor pulley has a grub screw to secure it so I drilled a hole in the shaft. For flat spots you could clamp the motor and take a dremel to it.
I doubt you’ll feel much of a push from one side of the board but a lighter rider would have to chime in here.
Yeah I have a dual 6355, this build is for my sister, wanted to go a bit cheaper than a dual drive, I am just wondering how big of a problem the pull is, if a problem at all.
Yea it would work. Shaft would be sticking out but it wont affect anything. And you could always get it chopped off later when you have access to tools.
I could trim it down for you with an angle grinder too. I dont mind
