Yes, it takes 6-12V (5V over usb) in and output 3.3V it says on the website so it appears this has a voltage regulator as would also be likely as a seperate regulator for 3.3V is not mentioned in the parts lists.
I think this is the RobotDyn one that Solidgeek also has linked on Aliexpress.
Looks like itās a combined SMD and TH moduleā¦ should work. Itās just a bit bigger than the regular one. Why u wanna use it? Just take the normal one. Or a high quality oneā¦
Sorry cbf reading through every solution on this thread - any quick fixes for intermittent cutouts?
I have built the remote and receiver according to this tutorial:
Itās plugged into a unity.
I added the power filtering to the receiver today but it didnāt fix the issue. In my skim through this topic I saw a few mentions of adding caps to the receiver Arduino between 5v and gnd. Is that the solution?
Im no expert, but when you say power filtering to the receiver (if u used something like a LC filter), i believe that would have the same effect as the capacitor
or FeatherRemote or TriggerRemote orā¦ all the remotes are smaller then the firefly. Firefly was a great start for all! I think no diy remote would there if soldigeek didnāt start with the firefly!
