OK I downloaded the one from your link. Same error
If youāve added the new VescUart library, you may need to remove any older libraries that are still installed. They can interfere with eachother because they all have .h files of the same names
Also, you should use the latest commit on the development version, rather than the master one.
Deleted the old ones. Iāll try the dev again but the arduini.h is missing in the uart library says ide
I also see that the new library has to be modified before use it. @clistpdx could you elaborate a bit more about it?
OK I have solved this error but now I get bldc measured values has incomplete type and cannot be defined
you first need to adjust the throttle at the remote level. Did you went inside the setting?
Iām programming the receiver. Does the remote has to be connected to it first?
no it will connect only when both of the part are loaded with the scripts. Now do the receiver. remember to use the same address
OK. But Iām stuck at the receiver with the bldc error
ah ok, didnāt have that error. Are you using the last develp branch?
I didnāt have to adjust any code. I think solidgeekās note there is trying to say that if youāve branched off and are using your own code you will have to make adjustments to it accordingly. I had no issue using dev version with his new VescUart library, on 4.3 firmware. Only trouble Iāve encountered are weak NRF connections. Trying now to isolate all the other components with copper tape. Iām also building zybās trigger remote which uses shielded NRFs and external whip antennas. Hoping to have better luck with that model.
Yeah.
I tried every version its all the same
Ah ok thanks for the clarification! Up to know I always used Ackmaniacās firmware. In that case should I keep use the old library or the new ones works also for the older firmware version? I guess not
That Iām not certain about. I havenāt tried ackmaniacās firmware personally.
OK receiver seems to be done but nobody here knows why xD Trying the remote now
ahahaha thatās normal some time!
Remote worked first tryā:rofl:
Thatās so true
But I canāt change the pages in the settings
