The vin goes through a 5V regulator and needs I think ~6.5V before it starts out putting a stable 5V. Using the 5V pin bypasses the regulator
Hello, so ive been watching this project for quite some time. I just received all the necessary parts to build the remote. everything is hooked up and ready to go, however im stuck on the software part. I went to solidgeeks webpage and downloaded all the latest firmware as well as the libraries, thats the U8g2 library and the vesc uart new version. I also have the latest transmitter and reciever software. When try to verify it says: Arduino: 1.8.6 (Windows 10), Board: âArduino Nano, ATmega328Pâ
Invalid library found in C:\Users\theli\Documents\Arduino\libraries\transmitter_code: C:\Users\theli\Documents\Arduino\libraries\transmitter_code Multiple libraries were found for âbuffer.hâ transmitter:15:18: error: RF24.h: No such file or directory
Used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-new compilation terminated.
Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-master Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-0.1.5 Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-master Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-0.1.5 Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-master Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-0.1.5 Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-master Not used: C:\Users\theli\Documents\Arduino\libraries\VescUartControl-0.1.5 exit status 1 RF24.h: No such file or directory
This report would have more information with âShow verbose output during compilationâ option enabled in File -> Preferences.
It also says that when i try to upload it. a couple of things to note, is when i try to get the board info it says:
BN - unknown board
VID - 1A86
PID - 7523
SN - upload any sketch to obtain it
Also when i try to do the wifi101 firmware certificate/updator test connection it says: programmer not responding.!!!
Please help
And thank you in advance
Just do everyone knows⌠discourse has code blocks
def hello
puts "world"
end
To do so have 3 of these (`) followed immediately by your programming language of choice so python Then whatever code you have , and close it off with the same characters used to start it
hello, thank you for the reply. So im not exactly sure what you mean by that. I put the three apostrophes in a row where it was giving me the RF24.h error but it said empty character content. I also put it in the beginning of the entire code and at the end but still did nothing. theirs also multiple errors?
exit status 1
VID - 1A86
PID - 7523
Iâm not sure what im suppose to take from this, its just a copy of the error message
Itâs to make it presentable so anyone who wish to help you can read it better
Ok, i appreciate it.
@solidgeek how did u calculate the pre resistor for the LEDs? 1kOhm looks much to high.
If I calculate for a blue led: 5V digital output 3V LED through voltage 18mA current = 111 Ohm ~ 120 Ohm
Did I miscalculate or misunderstood something?
I think this error might be in part because youâve installed multiple VescUart libraries. Each one contains a buffer.h but they conflict with eachother if you have more than one. Looks like you might have âNewâ, âmasterâ and one other named â0.1.5â installed. Just delete/uninstall all but the one you want.
thank you, I erased everything and started from scratch. I still get this error however and it wont let me upload:
Arduino: 1.8.6 (Windows 10), Board: âArduino Nano, ATmega328P (Old Bootloader)â
For anyone interested in a prebuilt, Iâve got 1 more currently available:
Have you installed the RF24.h library? There are a few libraries you have to install other than the VESCUART one.
Hey are you still selling these things? If so, can you make different colors?
Iâm not currently producing different colors right now
Thank you, I did that and it work. Transmitter is all good. So now the reciever code is giving me this error:
Reciever:127:2: error: âVescUartâ does not name a type
VescUart UART;
C:\Users\theli\Documents\Arduino\libraries\Reciever\Reciever.ino: In function âvoid setup()â:
Reciever:139:7: error: âUARTâ was not declared in this scope
UART.setSerialPort(&Serial);
C:\Users\theli\Documents\Arduino\libraries\Reciever\Reciever.ino: In function âvoid setCruise(bool, uint16_t)â:
Reciever:453:5: error: âUARTâ was not declared in this scope
UART.nunchuck.lowerButton = cruise;
C:\Users\theli\Documents\Arduino\libraries\Reciever\Reciever.ino: In function âvoid setThrottle(uint16_t)â:
Reciever:488:5: error: âUARTâ was not declared in this scope
UART.nunchuck.valueY = map(throttle, 0, 1023, 0, 255);
C:\Users\theli\Documents\Arduino\libraries\Reciever\Reciever.ino: In function âvoid getUartData()â:
Reciever:537:10: error: âUARTâ was not declared in this scope
if ( UART.getVescValues() )
exit status 1 âVescUartâ does not name a type
Hey, i have some questions about this remote:
- is it possible to use the switch for reverse mode? (would like to keep ppm with brakes but have possibility for reverse mode)
- is it possible to use said button for cruise control?
- do i have to connect uart pins on my master vesc, or is slave also ok? because i would like to have bluetooth module on master
thanks
Having the same issue, what are we doing wrong?
Hello, so my first issue was that I didnât install the rf24.h library. Now the second issue is for my reciever and it says the vescuart does not name a type. Iâm not sure what thatâs suppose to mean, Iâm a noob at coding. Any help is appreciated. Iâve read that if you basically downgrade to an older version of the arduino ide, some things will upload then on the newer version. Itâs because when the code is made in the older version, its specific to that version. Some things may be ok in the newer version because they havnt change, however, some other things may have. I just hope I can find a fix other then trying that.
Ah, I guess Iâll give that a try. Also having an issue getting the trigger to limit acceleration/braking in the OLED display, which is confusing because the trigger function works when booting into the settings, so I imagine my soldering connections are sound.
