check out this unit, 5v 2A e-bike usbport, there is a compact PCB inside (if desired, I can post a picture later today ) https://nl.aliexpress.com/item/Elektrische-Bike-USB-Charger-Output-5-V-2A-Voor-Mobiele-Telefoons-Ebike-36-V-48-V/32860737409.html
Hey guys, Iām just getting into all this electric skateboarding stuff and would like to know if anyone has made a video or has an instructions list containing something similar to a step by step of how to do this. I am considering making this alternatively to buying a winning v2 remote. I have a 3d printer so the case etc is no probem itās just the electronics inside that are kind of scaring me out of this. Thanks!
Yep, itās all buried in the thousand threads above @solidgeek has a tutorial: https://solidgeek.dk/docs/firefly-remote/getting-started/ and @seethebridges has a video tutorial. The first 3 parts are out already w/ more coming: https://www.youtube.com/watch?v=N032HqxeymA
My Oleds should be rated 3-5V, and they work from 5V rail when powered by usb (real measured voltage around 4.7V). I think the logic pins cant take over 5V thats why they fry when using my shitty boost converter. Or maybe because the boost converter doesn fit properly, something is pressing wrong place on it
Thanks so much!
One more question, I was just looking at sourcing all the parts and the nrf24 module on the parts list is "no longer available. I tried to find one but was unable to. Does anyone know where I could purchase one of these?
And if you canāt wait 30-50 days you can get them next week for a bit more cash: https://www.ebay.com/itm/1Pcs-2-4G-NRF24L01-PA-LNA-Wireless-Module-Ceramic-Antenna-1-27mm-For-Arduino-US/162862165321?hash=item25eb576d49:g:jrgAAOSw8d5ZRXQZ
When ordering from aliexpress, I always use the aliexprees standard shipping, it costs like 2,50e and delivery time is reasonable 12-21days to Finland. And use the same shop when ordering many items so only one shipping cost is added
I was unable to locate the code for the arduino, Iāve never used one before so is it just as easy as plugging it in and uploading the code? Also how does this connect to the ESC, and do I need more parts do make the connection. Thanks again for all the help Iām really new to this skateboarding thing. Here is the link to the ESC if needed products/torque-esc-bldc-electronic-speed-controller
Thereās the code, and youāll need to get the arduino IDE and a couple more libraries
Thanks! Appreciate it. Do you know how the remote connects to the board?
both the remote and the receiver have an arduino on board with a microUSB jack on them. Just watch the videos. Itās all in there
Sorry for all the questions. Are the videos on @solidgeek youtube channel as i couldnāt locate them Is it possible you could link them?
10 characters
Thanks again so much !!!
I couldnāt seem to find any of this in the thread above so here it is. I was wondering if you could put a USB C female jack instead of the micro USB one in the remote to charge it. Iām no electrician or anything and I know thereās not a whole lot of space in that area but Iām curios if one of these would work? If that doesnāt fit could you also use one of these? Iām not sure about the pin layout but couldnāt you directly solder onto them as to reduce space?
Yup should work fine. Only issue really is usb-c has the capability to have more than 5V supply (can go up to 20V according to Wikipedia) but so long as there is no connection to the CC pins it should default to 5V 500mA. In theory should work fine though (plus something will be able to plug directly into a MacBook pro 2017) https://en.m.wikipedia.org/wiki/USB-C
Would just check the vbus and G pins with multimeter with it plugged into the adapter(s) you plan to use to charge.
That USBc port is waaayyyyy too big to fit in the remote because of the PCB around it
