Could be the nrf24 module as you can see in my batch of modules one is odd.
This could just be that the third is using another chip or something that dosent require the other compoments. Havent tested the odd one yet.
Hey is there a definite list of everything that needs to be ordered? I started looking at the top of the thread and found the linked sheets doc, but I didn’t know if this has been updated as better components were found or not.
I’m planning on looking at building @ervinelin version but I’d assume that they are mostly the same parts. Just looking for your know working config. I can modify the code to suit my additions.
Thanks for the quick reply, because my lack of knowledge, capacitor is a electrolytic condensator? Mind you to give the values of this component, I will try to find it.
@Boesila I have been looking into the possibility to add a reverse function, however, I am not yet sure how to implement it. It will not be added to the next release
@Scoo_B_SK8 I have added a function to generate a unique address for each remote in the newest beta-build. Will be releasing the code soon!
@bsancken I believe the sheets document is updated with the newest parts.
@Surfer As long as you add a capacitor or use the Arduino Nano I recommend (with builtin 3.3V voltage regulator) it should not be a problem
I thought the remote can go reverse simply by letting go and triggering back via VESC-TOOL settings. Unless you mean a reverse function similar to pressing a button like the Winning V2?
